Replacing nut on Ibanez Wizard III neck http://luthiersforum.com/forum/viewtopic.php?f=10137&t=44140 |
Author: | raorn [ Fri Sep 12, 2014 7:43 am ] |
Post subject: | Replacing nut on Ibanez Wizard III neck |
Greetings, luthiers. I am about to replace nut on Ibanez XP300FX with 3pc Wizard III neck. Bought matching Graphtech Black Tusq XL 43x6mm nut, googled video instruction http://www.youtube.com/watch?v=tmUAuRs3Og0. Looks like it's not a Rocket Science - remove old nut, sand new nut, check strings height, glue new nut. Are there any caveats? Any common mistakes? Is there anything Wizard-specific or Tusq-specific I should know before I start? Is it OK to use PVA glue, or I should use Epoxy?.. |
Author: | Cal Maier [ Fri Sep 12, 2014 9:33 am ] |
Post subject: | Re: Replacing nut on Ibanez Wizard III neck |
PVA is fine, do NOT use epoxy. C~ |
Author: | dzsmith [ Fri Sep 12, 2014 5:36 pm ] |
Cal Maier wrote: PVA is fine, do NOT use epoxy. C~ And only a tad on the bottom of the nut. I use two small dabs. |
