witness lines? http://luthiersforum.com/forum/viewtopic.php?f=10137&t=45013 |
Author: | slash1953 [ Fri Jan 30, 2015 12:06 pm ] |
Post subject: | witness lines? |
Hi, A newbie on here,looks like a good forum to be?? Im about to restore a Fender Tele Bass (1970), I have to remove the thick brush applied enamel paint first and then `repair` the area that had been routed and filled before.I can see clearly the witness line wher the repair has sunk. Any ideas how to prevent is sinking again after Ive filled it please? ![]() |
Author: | WudWerkr [ Fri Jan 30, 2015 12:31 pm ] |
Post subject: | Re: witness lines? |
slash1953 wrote: Hi, A newbie on here,looks like a good forum to be?? Im about to restore a Fender Tele Bass (1970), I have to remove the thick brush applied enamel paint first and then `repair` the area that had been routed and filled before.I can see clearly the witness line wher the repair has sunk. Any ideas how to prevent is sinking again after Ive filled it please? ![]() Pics Please . Whats it filled with? |
Author: | SteveSmith [ Fri Jan 30, 2015 12:39 pm ] |
I like to fill repairs with wood not filler, then you don't have to worry about fill shrinking. But also depends on what you're trying to repair. Posting photos will help us. |
Author: | slash1953 [ Sat Jan 31, 2015 10:28 am ] |
As I said. Its on the body where a pick hole has been filled. Its sunk slightly and you can see the outline of the repair? I was thinking maybe to fill the joint line with super glue. Ps how do you send pics? |
Author: | EddieLee [ Sat Jan 31, 2015 11:04 am ] |
Quote: Ps how do you send pics? It has been awhile since I did that but try "Upload Attachment" in the box below the text screen. You may have to resize your photos to get under the size limit. The "Paint" program works good in Windows for that task. |
Author: | slash1953 [ Mon Feb 09, 2015 10:58 am ] |
slash1953 wrote: As I said. Its on the body where a pick hole has been filled. Its sunk slightly and you can see the outline of the repair? I was thinking maybe to fill the joint line with super glue. Ps how do you send pics? Im going to fill it with wood,but after a while you can see where the repair was? Heres some pics of the body,its hard to get a good shot of it? Finished in thick black paint!! http://i227.photobucket.com/albums/dd31 ... 2%2038.jpg http://i227.photobucket.com/albums/dd31 ... 2%2038.jpg |
Author: | B. Howard [ Tue Feb 10, 2015 8:52 am ] |
Hmmm....bet there is bondo lurking under that. I hate bondo, do not use bondo. I usually fill any small voids, low areas etc. after installing a wood plug with epoxy. |
Author: | slash1953 [ Tue Feb 10, 2015 9:03 am ] |
B. Howard wrote: Hmmm....bet there is bondo lurking under that. I hate bondo, do not use bondo. I usually fill any small voids, low areas etc. after installing a wood plug with epoxy. Cheers,Bud,will give it a try? Terry PS whats `bondo`? |
