Finishing after tung oil
http://luthiersforum.com/forum/viewtopic.php?f=10137&t=46036
Author:  baev_al [ Thu Jul 16, 2015 9:22 am ]
Post subject:  Finishing after tung oil
Hello friends.
How should I prepare the wood stained with tung oil if I want to finish it with acrylic lacqyer?
Thanks!
Author:  B. Howard [ Fri Jul 17, 2015 7:01 am ]
Post subject:  Re: Finishing after tung oil
You will need to sand it to provide a good anchor for the acrylic. If the wood is completely sealed and coated with tung oil sand at 320, otherwise prep at 180 as you would bare wood.
Author:  baev_al [ Fri Jul 17, 2015 8:15 am ]
I was ready for this )))
But maybe I can remove it with some solvent? Just maybe....
Author:  Frank Ford [ Wed Jul 22, 2015 11:07 pm ]
Shellac makes a great barrier coat, tends to stick to just about anything, and is the ideal undercoat for any kind of lacquer. Unless the thing is dripping with tung, I'd mix up some fresh shellac and wipe on a coat to see if it dries well.
