Irish coin quandary http://luthiersforum.com/forum/viewtopic.php?f=10137&t=46175 |
Author: | Chris Pile [ Thu Aug 13, 2015 8:21 pm ] |
Post subject: | Irish coin quandary |
OK, so I've got this Seagull 12 string... bought it for $15 off Craigslist. Headstock cracked - two big cracks down the neck right where the truss rod slot is routed. Unbolted the neck as soon as I got it home. Already yanked the fingerboard and truss rod assembly, and have it all glued back nicely. Some moron made a huge Magic Marker scribble on the top - buffed that off with Crest. Took the shiny off with some Scotchbrite. Problem? About halfway between the bridge and the tailblock on the center line, someone gouged an almost round hole, and glued in an Irish coin. The edge of the coin is proud of the top about 1/32 of an inch. Someone already tried to pry it out and poked a hole clear through the top, and put a nice divot right next to the coin. How the heck do I get this out? No idea what glue they used. And then, how shall I fill the hole. I mean - it's gonna be real obvious something happened there. Ideas, folks? |
Author: | Imbler [ Thu Aug 13, 2015 9:24 pm ] |
Post subject: | Re: Irish coin quandary |
Ok, just to get the ball rolling, I'll toss out a couple of ideas. Not having removed a coin from a guitar top, these are totally unproven. 1) drill small hole in coin and through top and thread in a screw. The right sized sheet metal screw should dig into the coin, yet be free in the top due to the taper at the end of the screw. 2) then heat the coin with a soldering iron. It should transmit heat very well to the glue no matter what kind it is and using the screw as a lever work the coin till it comes free. I'm guessing the resulting hole would be impossible to match to the top, so maybe a wood inlay matching your taste a little more than the coin does could be utilized to conceal the damage. Good luck with the project! Mike |
Author: | James Ringelspaugh [ Thu Aug 13, 2015 9:27 pm ] |
I put a few red flags down... maybe this will help in the future |
Author: | dzsmith [ Thu Aug 13, 2015 9:46 pm ] |
Coins should always be screwed on, not glued, in case you need some cash for a pack of smokes. |
Author: | Chris Pile [ Thu Aug 13, 2015 11:24 pm ] |
I like the hot coin idea - wasn't going to save the thing, anyway.... Next problem.... I am terrible at inlay. But Larry Ayres (an OLF member) is just down the road, and he's a monster at it. |
Author: | Chris Pile [ Fri Aug 14, 2015 2:30 pm ] |
NEWS: Coin removed via the heat method (good call, Mike). That thing is HARD, took awhile to drill through. Also, enough cured epoxy left in the hole to fill a pothole in the road out front. The guy glued in the coin to cover the gigantic hole left when someone stabbed the soundboard with a possibly sharp object. Now.... does anyone have a largish wooden coin to inlay? |
Author: | fumblefinger [ Fri Aug 14, 2015 9:17 pm ] |
I'd offer a hand, but have one of two covered in "splint" from surgery. I'd be tempted to inlay a contrasting wood, MOP, anything unique. Know any local artists who carve a copy of the Seagull symbol? It'd look like it belongs. |
Author: | Chris Pile [ Fri Aug 14, 2015 11:23 pm ] |
Thanks, Allan - but a nephew had a large wooden nickel with a buffalo on it. YES, in the mail. Sorry to hear about your hand. Should we get together this weekend and I'll take your mind off your troubles? |
Author: | Dave Rickard [ Sun Aug 16, 2015 8:43 pm ] |
Wooden Buffalo nickel adds a Kansas vibe to it. Sorry to hear about your hand Allan. |
Author: | Chris Pile [ Sun Aug 16, 2015 10:57 pm ] |
Quote: Wooden Buffalo nickel adds a Kansas vibe to it. Hope so, Dave. |
Author: | fumblefinger [ Mon Aug 17, 2015 12:22 am ] |
Anxious to see PICS with the wooden nickel! A few years back I inlayed Japanese coins that were first minted the year my Sensei was born in a custom pair of tonfa for him. To this day I don't think he's figured out that they were to cover a mis-drilled depth for the handle screw. "The mark of a professional is how well he can cover his mistakes" The surgery was for "tennis elbow" brought on by the D**m 6 string lessons. Should have stuck to bass. BTW, I'm still planning a get together in the new shop. Any members that are close enough to drive in are welcome. I also have a custom amp builder I plan to invite and one or two picker friends. It will probably be later part of September now. |
Author: | Chris Pile [ Sat Sep 12, 2015 11:30 pm ] |
Almost forgot about this.... finally got the wooden nickel inlaid (did an OK job). Got the cracks repaired, truss rod installed, fingerboard glued back on, and the neck bolted and glued back on. What a PAIN! Trying to hold the neck on to start the bolts, and got glue on my fingers. Now I can't let go of the bolts - they stick to my fingers. Anyway.... Reinstalled the nut and bridge, installed new tuners, grabbed some light Martin strings. OH MY. ![]() Click on link, and scroll forward through the 5 pix. http://s588.photobucket.com/user/studem ... sort=3&o=0 |
Author: | fumblefinger [ Sun Sep 13, 2015 11:37 pm ] |
Wow! What a gorgeous back on that thing! The crack repairs look good too. Heck of an investment. Let's see, $15 plus 80 hours of work, you'll need to get at least $2000 for it.... |
Author: | Chris Pile [ Mon Sep 14, 2015 8:51 am ] |
Quote: Wow! What a gorgeous back on that thing! The crack repairs look good too. Heck of an investment. Let's see, $15 plus 80 hours of work, you'll need to get at least $2000 for it.... It has cherry back and sides, I think. Thanks for the compliment, Allan. It wasn't quite 80 hours.... |
Author: | WudWerkr [ Mon Sep 14, 2015 9:20 am ] |
Those guitars are keepers , or usually given away to family /friend who can appreciate the time and effort |
Author: | Chris Pile [ Fri Dec 11, 2015 5:40 pm ] |
Just sold it on eBay for a pretty penny. It's headed to ol' Virginny. |
Author: | gxs [ Fri Dec 11, 2015 6:25 pm ] |
Chris, 1. Your story makes me wonder if this guitar was used to deflect a knife attack (hole), and then used to subdue the attacker (neck break). The coin would indicate . . . hmmm, was the guy you got it from in the Peaky Blinders? 2. As long as you have a hole to fill that you cannot hide, what about 3 shades of wood that look like your logo you use on the forum. GS Chris Pile wrote: NEWS: Coin removed via the heat method (good call, Mike). That thing is HARD, took awhile to drill through. Also, enough cured epoxy left in the hole to fill a pothole in the road out front. The guy glued in the coin to cover the gigantic hole left when someone stabbed the soundboard with a possibly sharp object.
Author: | Chris Pile [ Fri Dec 11, 2015 7:20 pm ] |
You made me laugh, George. I don't think it was used in an attack, but it's a good bet drinking was involved. I bought it from a guy stationed at Fort Riley, KS. I did consider a Studebaker logo (my avatar) for the filler, but I've used it before on other projects, and decided to give this one a pass. |
Author: | fumblefinger [ Fri Dec 11, 2015 11:37 pm ] |
Glad to see someone is selling something. |
Author: | Chris Pile [ Sat Dec 12, 2015 12:54 am ] |
Quote: Glad to see someone is selling something. It's been a good month. Sold that black Explorer and a purple Washburn... plus some small stuff. |
Author: | fumblefinger [ Mon Dec 14, 2015 1:16 am ] |
I think I counted at least 5 in the rack that I'd like to move. Two Squier basses, including one from the first/second year they made them in Korea, at least two neck repairs, the gold top JBLP, and maybe the ivory custom. Time to invest in a better bass. At least that's what the pain in my elbow, after playing a few chords for 15 minutes, is telling me. |
Author: | Bryan Bear [ Mon Dec 14, 2015 12:31 pm ] |
The magic marker part reminds me of a friend of mine. In Jr. high he won a stratocaster in some random drawing. It had a signature on the pickguard of someone we never heard of. He cleaned it off and was happy to have a free guitar. Years later, we all got into the music of Martin Sexton, and we have seen him multiple times. A few years ago he was cleaning out stuff left behind at his parent's house and came across his old journals. He showed me one particular entry where he writes about winning a free guitar "autographed by some guy named Martin Sexton. . ." |
Author: | Chris Pile [ Mon Dec 14, 2015 3:35 pm ] |
Yes..... but did it make the Strat play any better? |
Author: | Bryan Bear [ Mon Dec 14, 2015 3:47 pm ] |
Well he certainly didn't ![]() |
