| Advice Request! Trying to refinish my old guitar. http://luthiersforum.com/forum/viewtopic.php?f=10137&t=49980 |
| Author: | Mwhited93 [ Wed Nov 22, 2017 3:44 pm ] |
| Post subject: | Advice Request! Trying to refinish my old guitar. |
My goal originally was to strip the guitar down to the wood from a polyurethane finish and replace it with a nitrocellulose finish. However, I have had some issues removing the original finish via heat gun. Do I remove the layer underneath the finish (I think it's a sealer coat) to get to the wood, or have I gone too far on the front? If I have removed too much, what are possible solutions to even out the top? I've even considered doing a wood carving in it if nothing else, so all ideas are considered. ![]() Sent from my SM-G930R4 using Tapatalk |
| Author: | Freeman [ Wed Nov 22, 2017 4:49 pm ] |
| Post subject: | Re: Advice Request! Trying to refinish my old guitar. |
(Almost) any time you do a refinish you should go to bare wood and get all of the old stuff off. There is a good chance that whatever you put on top is not going to be completely compatible with the factory finish - particularly if its a catalyzed poly. Its also usually a real hassle to get the old stuff off. I've used chemical strippers followed by a fair amount of sanding. Generally nitro wants to be on a compatible sealer - shellac, vinyl modified sealer or sometimes just some well thinned lacquer. I'm guessing your guitar is ash or alder so it shouldn't need any pore filling |
