Discoloration of Martin Finish - How to Fix?
http://luthiersforum.com/forum/viewtopic.php?f=10137&t=54649
Author:  puffmogan [ Thu Dec 23, 2021 2:42 pm ]
Post subject:  Discoloration of Martin Finish - How to Fix?
I re-glued the binding and held it on for a few days with Blue Painter's Tape. The finish is now discolored as in the photo. I believe it's satin nitro. I have cleaned the surface and the discoloration remains. I think I can detect a slight smoothing of the finish where the discoloration is.
Recommendations on how to fix?
Author:  Colin North [ Thu Dec 23, 2021 3:15 pm ]
Post subject:  Re: Discoloration of Martin Finish - How to Fix?
Did you clean with naphtha?
Author:  puffmogan [ Thu Dec 23, 2021 6:08 pm ]
Thank you for your suggestion.
I cleaned with naptha and the marks are still there. I can find no trace of any substance on the surface.
Author:  bobgramann [ Thu Dec 23, 2021 6:39 pm ]
The adhesive in the 3M blue tape has an ingredient that dissolves nitro lacquer. There’s a warning in very small print inside the core. You may have some finish repair ahead of you.
Author:  johnparchem [ Thu Dec 23, 2021 7:10 pm ]
Just today Alan Carruth posted nearly an essay on how reactive nitrocellulose is in the classical guitar forum, and how many products react to it. It is worth a read.
Author:  Barry Daniels [ Fri Dec 24, 2021 9:52 am ]
I did the same thing about 10 years ago before I knew of the hazards of this tape. I was able to polish it out with my buffer.
Author:  Colin North [ Fri Dec 24, 2021 3:38 pm ]
I believe buffing will polish up satin nitro and change the sheen.
Author:  Barry Daniels [ Fri Dec 24, 2021 3:41 pm ]
Not necessarily. Most factory satin finishes are achieved by using flattening agent in the finish and polishing this will not change it from satin.
