| Removing long thru saddle on modern 'vintage' Martin http://luthiersforum.com/forum/viewtopic.php?f=10137&t=55217 |
| Author: | jfmckenna [ Sat Aug 27, 2022 12:29 pm ] |
| Post subject: | Removing long thru saddle on modern 'vintage' Martin |
It's my understanding that these are glued in with CA? Using my standard technique of a slit in cardboard protected by AL foil over the bridge exposing the saddle with a heat lamp simply will not work like it easily does on true vintage hide glue ones. And I mean I got this sucker HOT and just will not budge. What do y'all do? Just rout it out and start over? |
| Author: | Barry Daniels [ Sat Aug 27, 2022 1:06 pm ] |
| Post subject: | Re: Removing long thru saddle on modern 'vintage' Martin |
I have seen one technique where you saw down the middle of the saddle with a razor saw until you near the bottom. Then squeeze it from the sides with pliers to break the two halves free. I think I saw this on Frank Ford's site. |
| Author: | Cal Maier [ Sat Aug 27, 2022 5:57 pm ] |
+1 for Barry’s suggestion. It has worked for me with hard to remove or broken glued in saddles. I have used a circular saw in a dremel tool it worked fine, just take your time. |
| Author: | jfmckenna [ Mon Aug 29, 2022 6:18 pm ] |
Saw through worked like a charm, thanks. |
