It is currently Sat Jul 19, 2025 6:09 pm
 Post subject: Wiring
PostPosted: Thu Aug 19, 2010 8:35 pm
First name: matthew
Last Name: capeless
Could there be someone willing to help me? im bulding my first guitar and need help wiring if so please tell me! :)
neck pickup= humbucker (gibson 57 classic)
middle pickup= single coil (P-94R - Humbucker-Sized P-90 - Single Coil)
bridge pickup= humbucker (gibson 57 classic)
1 tone and volume to each pickup (500k pots, .22uf caps for tones) (no caps for the volume)
1 rotary switch
if anything is missing or need anything else please let me know, and no im not using a push-pull nob.
 Post subject: Re: Wiring
PostPosted: Thu Aug 19, 2010 11:08 pm
Last Name: Abercrombie
Matthew-
What do you want to do with the rotary switch? And what kind of rotary switch do you have?
PostPosted: Fri Aug 20, 2010 12:14 am
Matthew, the Seymour Duncan site: http://www.seymourduncan.com/support/wiring-diagrams/ has a lot of wiring diagrams. Maybe it will help you.
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Fri Aug 20, 2010 12:26 am
Rich-
Thanks for that link - now bookmarked here.
PostPosted: Fri Aug 20, 2010 8:16 pm
First name: matthew
Last Name: capeless
john i want the rotary switch to be a pickup selector and i dont know what kind
PostPosted: Fri Aug 20, 2010 8:49 pm
Things can get complicated in a hurry if you start trying to get a lot of different 'combinations' - and some of them may not be that 'interesting'-sounding.... or what you had in mind.
Using one of the 'standard' setups from the Duncan site, or trying out some combos with the pickups in a cheap 'test guitar' might give you some ideas.
PostPosted: Sat Aug 21, 2010 7:17 am
Last Name: Thiessen
City: Lexington Park
Lots of wiring diagrams here
http://www.guitarelectronics.com/category/wiring_resources_guitar_wiring_diagrams.3_pickup_guitar_wiring_diagrams/
cheers
John Thiessen
http://www.iszacguitars.com
PostPosted: Sat Aug 21, 2010 12:54 pm
First name: matthew
Last Name: capeless
your right maybe i should just use a 5-way
PostPosted: Sat Aug 21, 2010 11:45 pm
First name: matthew
Last Name: capeless
the links dont quite have what i want, im talking 5-way switch, humbuckers for the bridge and neck (specifically Gibson 57 classic) and a single-coil for the middle (specifically Gibson P-94R - Humbucker-Sized P-90 - Single Coil) wired to 500k pots with .20 capacitors for the tone. and obviously a jack.
PostPosted: Sun Aug 22, 2010 1:25 am
If you're not interested in running the humbuckers in single-coil/'split' mode, then you can just treat them like any single coil pickup - you'll have three pickups with two leads each- and one of the leads from each pickup will be connected to ground.
So the wiring becomes fairly simple.
I'm not sure about the output levels of your humbuckers and P-90 and how they will work when played together, but you will have a volume control on each pickup to help with that issue.
PostPosted: Mon Aug 23, 2010 12:40 pm
First name: matthew
Last Name: capeless
could you please give me a diagram? im not very good at wiring lol
PostPosted: Mon Aug 23, 2010 2:34 pm
Time to 'hit the books'.....
http://www.1728.com/guitar.htm
PostPosted: Mon Aug 23, 2010 9:07 pm
First name: matthew
Last Name: capeless
thanks
PostPosted: Mon Aug 23, 2010 9:16 pm
Matthew-
If you don't already own one, keep your eyes open for a cheap multimeter (needle-type- not digital). It's a big help in figuring out how switches work, and other 'troubleshooting' stuff.
It's not that complicated, really- you'll see!
PostPosted: Tue Aug 24, 2010 9:57 am
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
thanks, john.
pretty much sums it all up, all on one page.
PostPosted: Tue Aug 24, 2010 1:34 pm
alan stassforth wrote:
thanks, john.
+1! Great resource! Thank you!
PostPosted: Tue Aug 24, 2010 2:10 pm
Glad to help- I found that 'by accident' pretty quickly when I did a search.
