It is currently Sat Jul 19, 2025 1:36 pm
 Post subject: Re: Spring joints
PostPosted: Fri Apr 24, 2015 12:17 pm
First name: D
Last Name: S
If one assumes the ends shrink more in dry conditions, one must also assume the ends swell more in humid conditions. I'm going for straight joints.
wah
Wah-wah-wah-wah
Wah
PostPosted: Fri Apr 24, 2015 12:45 pm
Correct -- but I believe that makes the seam tighter, and is one of the reasons the sound-board or back puffs up in high humidity conditions, however usually without any permanent damage.
Ken Cierp
These users thanked the author kencierp for the post: dzsmith (Fri Apr 24, 2015 3:16 pm)
PostPosted: Fri Apr 24, 2015 9:54 pm
I try to get mine as perfect as possible using a #5 1/2, and check by pressing the halves against a window. It does take me a while...
PostPosted: Sun Apr 26, 2015 9:47 pm
First name: Jim
Last Name: Kirby
Burton LeGeyt wrote:
I make mine perfect before gluing but I did overhear someone whom I consider incredibly knowledgeable about wood and wood movement speak to this- basically he said that if you get the edge perfect on a square plate once you cut the body profile on the outer edge the mating edge will no longer be perfect- I never tried it but haven't forgotten it either.
But doesn't that imply that you glue up the plates after shaping for the body? Who does that?
Jim Kirby
kirby@udel.edu
PostPosted: Mon Apr 27, 2015 10:14 am
Well I don't know of anyone who does. I just shared it since it seemed relevant to the discussion. If the argument re: spring vs. perfect is taken further that would have to come into play. Realistically it is likely not an issue.
Burton
Brookline, MA.
PostPosted: Mon Apr 27, 2015 10:44 am
clean, straight, and light tight for me. i have a clamping fixture that i made: base plate, wax paper, back gage, wedges for pressure, and tops bars to keep everything flat.
it's so easy, why over-complicate?
