It is currently Sun Jul 20, 2025 12:22 pm
Post new topic Reply to topic  [ 126 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Thu Nov 23, 2017 12:48 pm
First name: Danny
Last Name: Vincent
Personally a fan of 5 of these. http://www.stewmac.com/Luthier_Tools/Ty ... lamps.html
PostPosted: Thu Nov 23, 2017 2:02 pm
If you apply HHG to the underside of a bridge it will move, more so in ebony than rosewood but both will move. That's why I glue size with thin HHG, allow it to dry and then check the underside of the bridge. With a little straight edge I virtually always find that the bridge needs to be scraped again and resized. I do it until the bridge stops moving, which is two or three times. Wetting the outer side of the bridge certainly helps a little but may not entirely eliminate it. Try the straight edge test on your next bridge, across it's width.
These users thanked the author Michael.N. for the post: Trevor Gore (Fri Nov 24, 2017 7:28 pm)
PostPosted: Thu Nov 23, 2017 2:35 pm
Actually, with the diminishing quality of available Ebony, there is a very real chance of slab cut Ebony and I have in fact encountered that problem on more than a few occasions IRL. HHG, with its excess water (in comparison to Titebond), can indeed immediately begin to warp slab Ebony, and it can be very difficult to tell orientation by looking at it. I also make my HHG a fairly thin blend as it seems to hold heat longer, someven more water.
I use HHG over Titebond simply for future serviceability. Well, and I like that HHG is a fixed target overnight when measuring the monopoles, whereas Titebond is a moving target for several days.
And Hesh, speaking of smoking the drapes...calm down, man:)
These users thanked the author meddlingfool for the post (total 3): klooker (Sun Nov 26, 2017 10:48 pm) • NightOwl (Sat Nov 25, 2017 10:42 am) • Trevor Gore (Fri Nov 24, 2017 7:28 pm)
PostPosted: Thu Nov 23, 2017 4:08 pm
Last Name: Farmer
City: Durango
State: CO
meddlingfool wrote:
....... I also make my HHG a fairly thin blend as it seems to hold heat longer, so even more water.
^^^^All my money goes there Ed. ^^^^^
It's not staying hot longer, it's gelling at a lower temperature.
There could be other things contributing but thinner hide glue is trouble.
These users thanked the author david farmer for the post: Hesh (Fri Nov 24, 2017 5:24 am)
PostPosted: Thu Nov 23, 2017 5:28 pm
My experience has been the opposite, the thicker the glue the faster the gel time. But I really don't know much more about it than what one reads on the web...
PostPosted: Thu Nov 23, 2017 5:29 pm
I'm putting my money on uneven clamping pressure, judging by the glue pattern on the top and the bridge.
These users thanked the author meddlingfool for the post: Hesh (Fri Nov 24, 2017 5:25 am)
PostPosted: Thu Nov 23, 2017 5:50 pm
My experience has been that it is easy to starve the joint with thin HHG
These users thanked the author jeffhigh for the post: Hesh (Fri Nov 24, 2017 5:25 am)
PostPosted: Thu Nov 23, 2017 5:56 pm
I'm with Trevor in the bridge curling: I've seen it. Fingerboards too. I don't scrape the bottom of the bridge flat, but hollow it just a little (a little!) from front to back for this reason.
The stress at the back edge of the bridge depends a lot on the length of the glue line along the line of pull; in other words, the width of the bridge. Increasing that length a little cuts the max stress at the edge a lot, and that's what the 'belly' bridge does. Once the bridge starts to peel the stress at the edge becomes even higher, and the failure moves faster, so the trick is to not let it get started. That's why it's so important that the edges be down tight, and why a little bit of swelling caused by water uptake can be such a problem.
Mario Proulx pointed out once that Martin used to 'tooth' the bottom of their bridges. This was supposed to strengthen the joint, but actually makes it weaker, so it contributed the problems they had with bridges lifting when they went to steel strings. The narrow bridges work fine if the surfaces are smooth, fresh, and fit properly.
Which brings up the subject of 'surface energy'. When you work a surface and remove material, you're actually breaking chemical bonds. Those open bonds create high 'surface energy'. It takes a while for these to find something to link onto, and if you hit them with glue they'll link to that. The Forest Product Labs found back in WW II that if you glue within 15 minutes of working the surface the bond is stronger.
The test for surface energy is to spritz the surface with a mist of water, which has polar molecules. If the water beads up the surface energy is low. If you use a microscope you can actually measure the angle between the drop and the surface at the edge and put a number on it. If the water spreads out in a film, the surface energy is high.
I once made a guitar with a fossil mammoth ivory bridge. The literature that came with the blank said that the stuff was hard to glue. It occurred to me that with material that old most of the chemistry had already happened, and the surface energy might be low, even on a pretty fresh surface. I tried the spritz and the water beaded right up. Scraping the surface got it to spread out, but not for long; if I dried it and came back later for a re-run it would bead up. So when it came time to glue the bridge down I had the clamps all set, got everything warm, gave the bridge bottom one last light scrape with a very sharp scraper, slapped on the hide glue, and got it down in a hurry. No problems.
These users thanked the author Alan Carruth for the post (total 4): Ken Jones (Sat Nov 25, 2017 4:08 pm) • Jonny (Sat Nov 25, 2017 1:36 pm) • Trevor Gore (Fri Nov 24, 2017 7:29 pm) • DennisK (Thu Nov 23, 2017 8:55 pm)
PostPosted: Thu Nov 23, 2017 6:11 pm
Heating with a hot air gun helps by drying the area to counteract swelling from glue application, as well as giving longer time before gel
These users thanked the author jeffhigh for the post (total 2): Trevor Gore (Fri Nov 24, 2017 7:29 pm) • Hesh (Fri Nov 24, 2017 5:25 am)
PostPosted: Thu Nov 23, 2017 6:51 pm
I've always been very wary of of heating the parts, fearing local changes in RH as well as slight shrinkage, but maybe I'm overthing it. But it only takes ~10-20 seconds to get the clamps on anyway so I haven't worried bout it.
Given that we haven't had a chorus of unanimous answers from the pic, it'll have to fall in the 'could've been' category. And again the smooth edge at the back makes me think it just wasn't clamped right.
It's back in place making noise again, and if it lifts again I'll know about it as the owner is fairly local.
PostPosted: Thu Nov 23, 2017 9:25 pm
Last Name: Farmer
City: Durango
State: CO
I think your misunderstanding what I'm trying to say.
Watery glue has a longer open time not because it is staying hot but because it gels at a much lower temperature. If your adding enough water to give a noticeably longer open time than the full strength mix, it'll be weaker.
On violin family instruments, hide is thinned to deliberately make it weaker for some joints. It's very effective.
What's your glue an water ratio?
These users thanked the author david farmer for the post: Hesh (Fri Nov 24, 2017 5:26 am)
PostPosted: Thu Nov 23, 2017 9:48 pm
I've never measured. I just add water til it behaves like I want it to...
PostPosted: Thu Nov 23, 2017 10:01 pm
First name: Frank
Last Name: Ford
City: Palo Alto
Zip/Postal Code: 94301
When I see a hide glue joint failure like that my first thought goes to technique - was it FULLY clamped before it cooled off to the gel state? That's a really big deal, and in my experience, the biggest problem in using the stuff. . .
Cheers,
Frank Ford
FRETS.COM
HomeShopTech
FRETS.NET
These users thanked the author Frank Ford for the post (total 2): Jonny (Sat Nov 25, 2017 1:37 pm) • Hesh (Fri Nov 24, 2017 5:26 am)
PostPosted: Thu Nov 23, 2017 11:13 pm
Great thread! I usually warm my bridge on a heating blanket at around 150 degrees via surface thermometer and warm the top with a hair dryer. Get it clamped up fast. Glue around 145 and about like honey.
The cupping with moisture is something I was not aware of although I've used BZ bridges almost exclusively for a long time and they are usually pretty well quartered.
It was interesting in the Goodall video posted recently to hear him extoll the greatness of Tightbond for bridges echoed by Trevor in this thread. Hummm-
PostPosted: Thu Nov 23, 2017 11:57 pm
Well, I'd like to think so, but...
PostPosted: Fri Nov 24, 2017 7:32 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Ed--
I had some bridges lift after using hide glue, and in order to keep it from happening again, I took a hard look at all aspects of the process and increased my awareness of everything I could, did everything a bit better, and I don't have problems any more. I guess my point is that you can drive yourself nuts trying to pin down the one thing that allowed this to happen, and you will probably never know for sure. But you can do everything in the future with an eye toward preventing this problem, and probably solve it.
For instance, you should fit the bridge and the footprint really well. You should use a thicker mix of glue. You should heat the parts. You should work fast. You should watch out for cupping of the bridge (this is a materials selection issue for new guitars). You should use multiple clamps. You should figure out a way for the weight of the clamps to not distort the clamping forces. If you watch out for all those things, I bet you won't see this problem any more. And yet you will remain in the dark about which specific thing (or combination of things) caused those failures in the past.
These users thanked the author doncaparker for the post: CraigG (Sun Nov 26, 2017 8:19 pm)
PostPosted: Fri Nov 24, 2017 9:10 am
First name: Greg
Last Name: Maxwell
City: Mount Vernon
State: Ohio
I'll add one more precaution, Don. Make dead sure that all traces of finish have been removed from the footprint. This can be more difficult than it sounds. An extremely thin trace of lacquer, for example, can be hard to see or feel. In the few instances where I've had lifting using Ebony and HHG, the problem was traces of finish.
It will probably be alright.
These users thanked the author Greg Maxwell for the post: Joe Beaver (Sat Nov 25, 2017 12:32 pm)
PostPosted: Fri Nov 24, 2017 8:07 pm
First name: Trevor
Last Name: Gore
City: Sydney
Hesh wrote:
Trevor if you are going to be smoking the drapes please have the decency to share?
:roll:. I think you've had enough already.
Hesh wrote:
Bottom line is we don't see slab cut bridges and for the life of me I'm sure Ed is not producing them either. So back to earth here and this thread what does this have to do with Ed's lifting bridge? Nothing!
Still in denial! Plenty of respected people have seen this. If the bridge curls and you don't spot it, no amount of the type of clamping likely to be pre-set for a HH bridge glue-up is going to give you conformity. If you do spot it, all you can do is abort and do something similar to what Michael does.
Ed's done way too many bridge glues, with too much success, to be caught out by the basic stuff. Sure, we can all improve our processes, but this failure has all the trademarks of a joint not properly closed, most likely because it was un-closeable because the bridge curled.
http://www.goreguitars.com.au
PostPosted: Fri Nov 24, 2017 8:11 pm
First name: Trevor
Last Name: Gore
City: Sydney
Hesh wrote:
Clay S. wrote:
Not to join the "Pick on Trevor Bandwagon" but:
"classical bridges which are arguably under even more stress"
I've used a simple rubbed joint with HHG and no clamps for classical bridges and not had them fail. I'm too chicken to try this for steel strings.
Completely agree. String tension is not difficult to calculate, classicals have much less string tension...
Probably better to understand the difference between tension and stress before you make a comment like that.
These users thanked the author Trevor Gore for the post: Joe Beaver (Sat Nov 25, 2017 12:32 pm)
PostPosted: Fri Nov 24, 2017 9:26 pm
I'd like to believe it wasn't me, but I've worked with myself way too long to believe that.
I did reuse the old bridge, so if the problem is indeed slab Ebony, I'll find that out again one day I'm sure. Fortunately the guitar in question belongs to a friend so no big deal if it does.
I am inclined to think that I clamped it wrong, and that the glue may have been too thin, and that gluing a flat bottomed bridge to a domed top isn't the best idea even though it usually works fine and that maybe I'd be better off with the light horseshoe style SM clamps rather than the big F clamp I use now.
I'm putting it into the 'any number of things' pile and moving on.
Thanks everyone, peace out...
PostPosted: Fri Nov 24, 2017 10:24 pm
First name: Trevor
Last Name: Gore
City: Sydney
In the book (Build, p. 20-8, penultimate paragraph), I talk about a jig I use for shaping the bottom of a bridge. I laminated a bunch of thin ply into a building dish, using a lot of go-bars, so I had a convex surface when flipped. Stick sand paper onto that and you can rapidly get a spherically curved bridge base to match your top. Different radii/shapes to match the appropriate top curves, of course. The lump of wood beneath is so I can hold it in a vise. Only takes a couple of minutes of sanding, so not much impact on your production. Be sure to clean off the sanding dust.
These users thanked the author Trevor Gore for the post (total 3): Bryan Bear (Tue Nov 28, 2017 1:52 pm) • Jonny (Sat Nov 25, 2017 1:42 pm) • Joe Beaver (Sat Nov 25, 2017 12:31 pm)
PostPosted: Fri Nov 24, 2017 11:15 pm
Online
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
I used to do something very similar to what Trevor describes above to fit the bridge to the top. But, even though my shop humidity is closely controlled and I glue the braces and bridgeplate in a dish, I found some variation in the top shape when it came time to glue the bridge. I really wanted the surfaces to meet perfectly, so I have been sanding the bridge bottom to the shape of the top on the top. I use a fresh sheet of 120 sandpaper held in the bridge location, mark the bottom of the bridge with crosshatched pencil lines, and sand the bridge against the sandpaper on the top until the pencil lines disappear. I sand in very small circles (a few millimeters in diameter) so that the bridge bottom picks up the local topography of the top at the bridge foot print. I test the result by pulling thin strips of paper between the bridge and the top with the bridge lightly held on position. If the paper doesn’t drag, the bridge doesn’t fit. I thought everyone did it this way. It does take me some time, but I get the fit that I want.
These users thanked the author bobgramann for the post: Colin North (Sat Nov 25, 2017 4:30 am)
PostPosted: Sat Nov 25, 2017 5:26 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
We use a 28' radius dish for the top (with 28' radius braces on all but the 60' upper transverse brace), so making 28' radius convex sanding form is easy - just sand a 10" x 8" piece of 18mm MDF in the dish and mounting PSA 80 grit. The mating surface of the bridge plate is also milled to 28' radius, so top, bridge plate, and bridge all conform to the design top radius.
Despite what might be a lower moisture content for Titebond where a lower solids mix of hot hide is used, we will not usually glue or reglue bridges with thermoplastic glues. The primary issue with Titebond for constantly stressed joints is that even with thin glue lines, these glues are prone to both cold and hot creep. We see enough cold creep on recently made instruments that separation of the lacquer along the front edge of the bridge due to shear forces occurs. Both the SCGC 000 and Martin 000-28EC - owned by conscientious musicians that do not subject their instruments to adverse storage or use conditions - came in for repair required extensive touch-up around the edge of the bridge patch to restore the finish.
- Beth Brower
These users thanked the author Woodie G for the post (total 2): Jonny (Sat Nov 25, 2017 1:44 pm) • Hesh (Sat Nov 25, 2017 8:41 am)
PostPosted: Sat Nov 25, 2017 6:21 am
Trevor probably better to pull your head out..... and not be the arrogant SOB that you clearly are before you make a comment like that..........
You need to spend some time in the trenches doing copious amounts of repair work and stop breathing your own air. As Rick Turner used to say on this forum you don't know **** until you learn to do some repair work.....
PostPosted: Sat Nov 25, 2017 6:33 am
Bob you mean like this: http://www.luthiersforum.com/forum/viewtopic.php?f=10117&t=25513&p=344237&hilit=fitting+a+bridge#p344237
UPDATE: I no longer fit bridges this way because it takes too long and after a while you get pretty fast at fitting them simply using a single edged razor blade and careful observation. Fitting bridges is something that we do nearly every day making for lots of practice.
The other change is the bridge rabbiting that we do with most finishes that have any thickness to them. I may nix the rabbiting on FP shellac or other very thin film finishes where there is a very minimal finish ledge.
