It is currently Sun Jul 20, 2025 11:12 am
 Post subject: Bridge Pin Reamers?
PostPosted: Fri May 24, 2019 4:52 pm
First name: Nathan
Last Name: Peirson
Hi all, I am wondering which bridge pin reamers folks use. I see there are 2-5 degree reamers out there and some are pricey while others are not? I assume that is quality of the steel and hardness, etc. Just wonder what folks are happy with?
 Post subject: Re: Bridge Pin Reamers?
PostPosted: Fri May 24, 2019 8:02 pm
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
I have an inexpensive one that I bought from Grizzly years ago. I use the unslotted pins made by Gurian’s company and they fit fine with this reamer. It does the job.
PostPosted: Fri May 24, 2019 8:27 pm
I took a page from Trevor Robinson's book and ground the tang of a file into a bridge pin hole reamer. It only took a few minutes to do and works O.K. It doesn't hurt the functioning of the file and you could still put a handle on it if you didn't mind removing it when you needed to ream pin holes.
PostPosted: Fri May 24, 2019 9:23 pm
StewMac 5 and 3 degree reamers and I've used mine commercially often using them every day for over a decade now. Excellent steel, still sharp as can be, got my money's worth and I'm happy with many more reams to go from these likely.
The ROI may not be there for builders who ream as often as you complete an instrument.
PostPosted: Sat May 25, 2019 12:18 am
First name: Joshua
Last Name: Groeshne
City: Kawkawlin
Zip/Postal Code: 48631
I made a mini version of a chairmaker's reamer. It matches whatever angle my bridge pins were. The blade is a broken hacksaw blade. It works surprisingly well.
Sent from my SM-J320V using Tapatalk
PostPosted: Sat May 25, 2019 6:37 am
Last Name: Tracz
I have the 3 degree reamer from LMII and love it.
_Mike Tracz
MCT Guitars
https://www.instagram.com/mustcreatethings/
https://www.youtube.com/mustcreatethings
PostPosted: Sat May 25, 2019 7:43 am
3 and 5 degree reamers from SM, never regretted biting the bullet and coughing up for them, but I do repairs as well.
I prefer 3 degree tapes for my builds, but good pins not always available in UK at a reasonable price.
PostPosted: Sat May 25, 2019 9:56 am
Last Name: Kincheloe
I use the StewMac 3 degree, and it works very well. I also have a Grizzly 3 degree, which is fairly useless. Technically it does get the job done, but at the cost of your wrist :) It takes a lot of pressure before it will cut.
PostPosted: Sat May 25, 2019 12:02 pm
Same here.
PostPosted: Sat May 25, 2019 6:03 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
I've have a 5° reamer that I bought from LMI years ago and it's worked fine for the 7 acoustics I've used it on.
I recently bought a 3° reamer from Philadelphia Luthier Tools on Ebay. I tested the reamer, it cut quickly and matches my 3° pins. Haven't used it on a build yet but it appears equal to the LMI.
Kevin Looker
I'm not a luthier.
Users browsing this forum: ChuckB, George L and 9 guests
