It is currently Thu Sep 18, 2025 11:38 am
 Post subject: Neck Angle question
PostPosted: Tue Sep 16, 2025 9:51 am
First name: robin
Last Name: courtenay
City: andover
State: hants
Country: uk
Ok got my neck finished fretboard on and fretted ,when i check with straightedge it just grazes top of bridge which is 3/8 inch. Is this in the ball park? Thanks Rob.
These users thanked the author roby for the post (total 2): stumblin (Thu Sep 18, 2025 4:33 am) • Michaeldc (Tue Sep 16, 2025 12:35 pm)
 Post subject: Re: Neck Angle question
PostPosted: Tue Sep 16, 2025 10:24 am
[:Y:]
PostPosted: Tue Sep 16, 2025 11:21 am
Perfect, well done!
PostPosted: Tue Sep 16, 2025 4:08 pm
It will be probably be alright, but I shoot for at least a 1/16" above because the top will rise a little. also it gives more saddle above the bridge for future settling in.
PostPosted: Thu Sep 18, 2025 4:11 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
Interesting question. Assuming you wish to get something close to 1/2" final string height over the top at the bridge on a new/never strung traditionally constructed flattop guitar, I would lean towards Mr. Goodman's suggestion. On a reset of an older instrument, I would tend toward agreement with Mr. North's 'thumbs up' response. Is this new construction or a reset?
Why this matters:
A new flattop guitar will 'settle' over the first few months, with much of that body distortion or apparent 'top rise' occurring within a week or so after stringing up. A lightly constructed instrument might see as much as .060" apparent rise in the top (really an aggregate of back, side, and top distortion due to loading), while something built to the approach Guild took on much of their Westerly 6 string production might see closer to .030 inch change. This is the basis upon which I feel Mr. Goodman's response reflects what you may see if your instrument is in fact new construction.
For an existing instrument, we usually have the advantage of knowing something about how much change we might see in string height above the top under load with measurement both under load and unloaded. Most existing instruments have distorted such that - even with load removed - much of that top rise/distortion is already locked in place. If Mr. Goodman's suggestion on new construction neck geometry is IMO inappropriately applied to a reset on an older guitar, I believe most repair people would anticipate an over-set.
Further, resets must deal with the guitar as it is versus how it might have left the shop or factory decades earlier, to include bridge thicknesses below or above what might be considered optimal as well as overall construction (e.g., 00-21NY versus a 1970's D-28). Further geometry adjustment might be required to avoid a very tall saddle on a thin bridge (with possible structural failure of the saddle slot) or deliver a guitar back to the customer with a very weak reset and minimal benefit to volume, note-to-note separation, projection, and change in saddle height.
- Beth Brower
These users thanked the author Woodie G for the post: stumblin (Thu Sep 18, 2025 4:34 am)
