Official Luthiers Forum! https://luthiersforum.com/forum/ |
Router caution! https://luthiersforum.com/forum/viewtopic.php?f=10101&t=44328 |
Author: | PeterF [ Sat Oct 11, 2014 5:27 pm ] |
Post subject: | Router caution! |
Just a quick cautionary tale I have from today... I was routing the binding channels on my current guitar. I use a router table with a homemade binding jig mounted to it and hold/move the guitar rather than vice versa. So it was all going fine, then in a moment of unthinkingness I started a cut going in the opposite direction (going with the blades rotation) and BAM the guitar was out of my hands and halfway across the room! ![]() ![]() Of course it could have been prevented by having a new sharp router bit and concentrating more, but who can say they always do that? |
Author: | Alex Kleon [ Sat Oct 11, 2014 5:53 pm ] |
Post subject: | Re: Router caution! |
Glad your accident didn't cause any damage to you or your guitar Peter. Gives you a bit of the shakes though, doesn't it! ![]() Alex |
Author: | Tom West [ Sat Oct 11, 2014 6:15 pm ] |
Wakes one up and gets the blood pumping....!!! Tom |
Author: | Kamusur [ Sat Oct 11, 2014 10:52 pm ] |
Wouldn't keep doing it like that myself Tom, always go for the two handed approach with any power tool. Better to lose an instrument across the room than a digit or two. Steve |
Author: | dzsmith [ Sat Oct 11, 2014 11:18 pm ] |
Yep, my routers scare me the most of all my power tools. I'm doing more stuff by hand. Takes longer, but less likely to blow out chunks of wood and fingers. |
Author: | DennisK [ Sat Oct 11, 2014 11:33 pm ] |
Yikes! I'll stick with my gramil and chisel. |
Author: | bluescreek [ Sun Oct 12, 2014 7:12 am ] |
I think I used every binding jig out there. When it comes down to the time investment , you need to consider the safest and most repeatable method you can afford. Be thankful your project or you were not harmed. Lesson learned. |
Author: | Bobc [ Sun Oct 12, 2014 7:46 am ] |
Routers can scare the hell out of and cause some serious damage to your fingers. When using any power tool put on your safety glasses and concentrate on what your doing.... take it slow and easy. I've had my buffer fling a guitar down to the ground, Wasn't so lucky. Had to replace the top. ![]() |
Author: | Haans [ Sun Oct 12, 2014 8:34 am ] |
Colin North wrote: I really don't mean to be rude, but.. I's so simple and quick to make up a secure holder for a body that I find that hard to believe. That is just an accident waiting to happen. This is worth repeating. Most folks rout binding backwards, and it's worth taking the time to build or buy a holding jig or sled. Two handing the box is almost a requirement if you are moving the box into the router. Overarm routing is probably the best way to go and the sled will provide resistive friction as you also push it onto the bench surface. If you are holding a "hand held" tool, the holding jig is almost mandatory as you should be two handing the router. One handing a router is only good for trimming laminate, as it's pretty hard to fling a counter top across the room. Buffing is another story. Care and attention is of utmost importance. It's one of those middle of the day jobs when you are wide awake and not too tired to be inattentive. |
Author: | Tom West [ Sun Oct 12, 2014 8:53 am ] |
Steve: Thanks for the concern but I think this operation with the router is relatively safe for me, much less so for the guitar if I let my guard down. The bit is not very exposed and quite sheltered. Been doing it this way since the 70's but as my wife says "Just because you have always been doing something a certain way for a long time doesn't mean it's right."...................My wife is MUCH smarter then me...!!! Tom |
Author: | Tom West [ Sun Oct 12, 2014 9:05 am ] |
Bob: Table saws scare the brown stuff out of me...!! Over the years I have been bitten a couple of times by a power tool.........both were by my favorite and most used power tool............. a table saw. Thankfully I still have 8 fingers and 2 thumbs. Don't use routers very much but I certainly understand your feeling for anyone using one on a regular basis. Tom |
Author: | mflazar [ Sun Oct 12, 2014 9:06 am ] |
I very much agree with Bentrup. The set up I use took me very little time and it seems to be fool proof. I made this stuff over 20 years ago and it will easily outlive me. Attachment: Assembly~042.jpg
Author: | Michaeldc [ Sun Oct 12, 2014 9:09 am ] |
When I buff, I wear palm coated Atlas type gloves. They are nice and grippy! Much harder to have the guitar ripped from your hands if you loose focus. |
Author: | Colin North [ Sun Oct 12, 2014 1:07 pm ] |
Michael, just buffed out one other day, and wearing similar coated gloves saved me a wrecked box when I caught a top edge and it wanted to go walkabout at a very brisk pace. |
Author: | unkabob [ Sun Oct 12, 2014 3:23 pm ] |
Michael: My setup is much like yours. I use wooden drawer slides for vertical guides but now I added a counter-weight and the guides seem a tad sticky. What do you use. Bob ![]() |
