Official Luthiers Forum! https://luthiersforum.com/forum/ |
My latest https://luthiersforum.com/forum/viewtopic.php?f=10101&t=50102 |
Author: | Casey Cochran [ Fri Dec 29, 2017 2:44 pm ] |
Post subject: | My latest |
I recently finished this Coco/Sitka OM. Cardinal lacquer over epoxy pore fill, satin tung oil modified urethane neck. 1 11/16" nut, Waverlies and K&K Pure Mini pickup. Sorry about the sun washed pics, I don't really have a good setup for shooting guitars. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk |
Author: | bcombs510 [ Fri Dec 29, 2017 3:11 pm ] |
Post subject: | Re: My latest |
A beautiful instrument. Nice work! Sent from my iPhone using Tapatalk |
Author: | sdsollod [ Fri Dec 29, 2017 3:51 pm ] |
Really Nice Casey! Thanks for posting. |
Author: | fingerstyle1978 [ Fri Dec 29, 2017 4:27 pm ] |
Looks Great! |
Author: | George L [ Fri Dec 29, 2017 4:40 pm ] |
That's a fine looking instrument. Well done! |
Author: | Mike OMelia [ Fri Dec 29, 2017 4:49 pm ] |
Sweet! |
Author: | Glen H [ Fri Dec 29, 2017 5:35 pm ] |
I love traditional! Great job. |
Author: | Haans [ Fri Dec 29, 2017 6:07 pm ] |
Very nice! Is that ivoroid? |
Author: | bionta [ Fri Dec 29, 2017 6:50 pm ] |
So nice! |
Author: | Alex Kleon [ Fri Dec 29, 2017 7:20 pm ] |
Beautiful, Casey! That is a great set of coco, and you absolutely made the best of it! Alex |
Author: | Casey Cochran [ Fri Dec 29, 2017 7:46 pm ] |
Haans wrote: Very nice! Is that ivoroid? Thanks, yes, it's ivoroid. Sent from my iPhone using Tapatalk |
Author: | Terence Kennedy [ Fri Dec 29, 2017 9:14 pm ] |
Looks great. Is that a drop in thru-saddle or glued? |
Author: | Casey Cochran [ Fri Dec 29, 2017 9:22 pm ] |
Terence Kennedy wrote: Looks great. Is that a drop in thru-saddle or glued? Thru-saddle. It's tight enough that I didn't glue it. Are they typically glued to keep them from sliding or to strengthen the front edge of the bridge? Sent from my iPhone using Tapatalk |
Author: | Freeman [ Sat Dec 30, 2017 11:44 am ] |
Very nice Casey. Question about your finish - did the coco have any tendency to bleed when you applied the pore fill or with the lacquer? I'm building with coco right now and every wipe of alcohol or acetone carries a great amount of redish brown oil onto the rag - I'm afraid that any solvent will carry oil into my light fiber purfling strips and even to the top. I'm also planning to use Zpoxy with either nitro or KTM-9 over that and I'm considering doing the pore fill before I route the channels for the binding and install it. |
Author: | Clay S. [ Sat Dec 30, 2017 12:53 pm ] |
Classic design, Nice straight grained wood, lovely finish - Bravo! |
Author: | Casey Cochran [ Sat Dec 30, 2017 2:23 pm ] |
Freeman wrote: Very nice Casey. Question about your finish - did the coco have any tendency to bleed when you applied the pore fill or with the lacquer? I'm building with coco right now and every wipe of alcohol or acetone carries a great amount of redish brown oil onto the rag - I'm afraid that any solvent will carry oil into my light fiber purfling strips and even to the top. I'm also planning to use Zpoxy with either nitro or KTM-9 over that and I'm considering doing the pore fill before I route the channels for the binding and install it. Yes, it bled a little. I had to scrape the bindings, but the purflings and back strip were fine. |
