https://luthiersforum.com/forum/
Forearm contour, bindings
https://luthiersforum.com/forum/viewtopic.php?f=10101&t=52039
Author:  Tai Fu [ Wed Jun 12, 2019 11:35 am ]
Post subject:  Forearm contour, bindings
So I want to think about doing a forearm contour on my next build...
I never tried to do it before but I felt the easy part is putting the wood inside and shaping the actual contour itself, the hard part is bindings.
How are bindings done on forearm contours? It seems like it's impossible to do with just a hand router because of the irregular surface. I seen one guy just make a template, is that how it's done? What about the side purfling?
This just seems like a CNC job...
Author:  Colin North [ Wed Jun 12, 2019 12:46 pm ]
Post subject:  Re: Forearm contour, bindings
That' the way I've seen it done, using a template. Same for the side purfling, template.
What's CNC? Not something for building guitars surely.
Author:  sdsollod [ Thu Jun 13, 2019 9:35 am ]
Do you mean an arm bevel? If you don't mind taking an on-line class for a reasonable price this is a good resource. Kent Everette shows you how he does it. I followed his instruction and was pretty pleased with the results.
https://obrienguitars.com/courses/arm-bevel
Author:  Colin North [ Thu Jun 13, 2019 10:20 am ]
Here's a freebie https://www.youtube.com/watch?v=CK_EVunKZQg&t=6s
Author:  Colin North [ Thu Jun 13, 2019 10:37 am ]
Or buy an American Lutherie #110 https://www.luth.org/back_issue/al109-112/al110.html
"Making a Scoop Cutaway and Armrest Bevel by Jeffrey Yong
Here’s a step-by-step photo essay of making the cutaway and armrest by using angled interior blocks and then cutting into them after the instrument is assembled."
Author:  Tai Fu [ Thu Jun 13, 2019 11:15 am ]
thanks for the tips. I think that tips du jour tells me everything I need to know.
Sounds like making the template and shaping the bevel to that template is a better way to go about this than making a template for every guitar that gets an arm bevel.
I have some practice to do.
Author:  Mark Mc [ Fri Jun 14, 2019 6:48 am ]
Mike Doolin came up with a really clever alternative way to do a forearm contour. Not a side bevel, but a bent top. He gives a pictorial tute here:
http://www.doolinguitars.com/articles/armbevel/
Author:  DennisK [ Fri Jun 14, 2019 3:43 pm ]
My method, using giant dentellones rather than a solid block http://www.luthiersforum.com/forum/viewtopic.php?p=645146#p645146
