Official Luthiers Forum! https://luthiersforum.com/forum/ |
New Year, New ELEVATE Tool- Dot Driller https://luthiersforum.com/forum/viewtopic.php?f=10101&t=52784 |
Author: | Chris Ensor [ Wed Jan 01, 2020 8:27 am ] |
Post subject: | New Year, New ELEVATE Tool- Dot Driller |
Attachment: Dot Driller Thumb OLF.jpg Happy New Year! What better way to ring in the new year than with a new tool? Introducing, the ELEVATE Dot Driller- this simplest way to make your own side dots. It's used in a drill press and available in both 3/32" and 2mm. Inside it's tool steel body is a spring loaded aluminum ejector pin. Now creating side dots is as easy as drilling into your material of choice. Once you break thru the material or the plug breaks free, turn off the machine and pop the plug out with the ejector pin- then repeat. It's that simple! Head over to the website and watch the tutorial to see it in action. https://ElevateLutherie.com/product/dot-driller/ |
Author: | Pmaj7 [ Wed Jan 01, 2020 12:20 pm ] |
Post subject: | Re: New Year, New ELEVATE Tool- Dot Driller |
Cool! Pat |
Author: | Terence Kennedy [ Thu Jan 02, 2020 7:32 pm ] |
What speed do you run it at in the drill press Chris? |
Author: | Chris Ensor [ Thu Jan 02, 2020 9:53 pm ] |
Terence Kennedy wrote: What speed do you run it at in the drill press Chris? Hmm... Haven't checked the actual "speed" of my drill press in a while. But I run it pretty fast. It's a small diameter. |
