Official Luthiers Forum! https://luthiersforum.com/forum/ |
Buffing into the corner with the neck attached https://luthiersforum.com/forum/viewtopic.php?f=10101&t=53423 |
Author: | Brad Goodman [ Thu Aug 13, 2020 9:47 pm ] |
Post subject: | Buffing into the corner with the neck attached |
A little while ago someone was asking about buffing in the corner when you have the neck on. Like I said it should be just as shiny as the rest of I tried to take a few pictures to show it here. ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk |
Author: | Chris Pile [ Thu Aug 13, 2020 11:10 pm ] |
Post subject: | Re: Buffing into the corner with the neck attached |
Nice! |
Author: | Barry Daniels [ Fri Aug 14, 2020 10:16 am ] |
Tools and methods please. |
Author: | bftobin [ Fri Aug 14, 2020 11:24 am ] |
Felt bobs and a multi-tool ??? |
Author: | Brad Goodman [ Fri Aug 14, 2020 1:59 pm ] |
Barry Daniels wrote: Tools and methods please. I am using the same 14" buffs that I do the rest of the guitar with.... The only thing I change is instead of using my usual double buffs ,I remove one which makes the buff more flexible. It's just a matter of really getting into the corner as tight as you can. I apply a good amount of pressure-but not so much as to burn the lacquer. |
Author: | Tim Mullin [ Fri Aug 14, 2020 6:41 pm ] |
Brad Goodman wrote: Barry Daniels wrote: Tools and methods please. It's just a matter of really getting into the corner as tight as you can. I apply a good amount of pressure-but not so much as to burn the lacquer.I suppose one thing I learned NOT to do is aim the buff directly into the corner, in hopes that a jammed buff with enough pressure will reach into the corner. I found buffing perpendicular to the side as well as perpendicular to the heel created a better finish. You can vary pressure and angle a bit to splay the buff edge into the corner. It takes practice. Buffing this close to the corner while perpendicular to the side has the added hazard that the neck is perilously close to the big nut on the buffer. I had to hit it a couple of times before I learned! Sent from my iPad using Tapatalk |
