https://luthiersforum.com/forum/
Fret file handle
https://luthiersforum.com/forum/viewtopic.php?f=10101&t=53652
Author:  Ruby50 [ Fri Nov 06, 2020 3:15 pm ]
Post subject:  Fret file handle
StewMac has just come iwth a handle for your fret files
https://www.stewmac.com/luthier-tools-a ... C_20201106
Seems like an interesting idea, especially for the thinner ones that want to flex. Does anyone have a solution they want to share?
Ed M
Author:  Chris Pile [ Fri Nov 06, 2020 3:22 pm ]
Post subject:  Re: Fret file handle
Don't force it?
Author:  Hans Mattes [ Fri Nov 06, 2020 3:31 pm ]
Pull, don't push.
Author:  Clay S. [ Fri Nov 06, 2020 4:01 pm ]
I watched the video. Dan didn't use one. pizza
It doesn't look like a bad idea, but for the price I would buy a few more fret files rather than the holders. It does look like something you could make in the shop easily enough if you were so inclined.You could cut a kerf in a piece of wood and make a long thin (removable) wedge to hold the nut file in place.
I usually saw the nut slots with various width kerf saw blades and use the nut files to smooth and refine the size of the slots. I don't force them.
Author:  J De Rocher [ Fri Nov 06, 2020 4:36 pm ]
When I make a nut, I go back and forth between the individual files a lot during the process. That means I would want to buy multiple handles so I wouldn't have to be constantly tightening and loosening four hex screws to swap the handle between files. For my file set, I would want three handles for the three thinnest, most flexible files. That's about $36.00.
I suspect that the handle would make it harder to see what's going on right at the nut since it would block the view from above and behind.
Author:  Clay S. [ Fri Nov 06, 2020 7:03 pm ]
That was my thinking also - swapping files in a single holder would be a PITA, which sways it to the make side of a "make or buy" decision. But so far I've lived without, so that could work too.
