Official Luthiers Forum! https://luthiersforum.com/forum/ |
Watcom EGO HVLP gun https://luthiersforum.com/forum/viewtopic.php?f=10101&t=54814 |
Author: | Mike OMelia [ Fri Mar 04, 2022 4:05 pm ] |
Post subject: | Watcom EGO HVLP gun |
It went from being a great sprayer to crap in a week. I was spraying nitro with color tone dyes. Can’t put down a wet coat. Anybody know why? Mike |
Author: | SteveSmith [ Fri Mar 04, 2022 4:11 pm ] |
Post subject: | Re: Watcom EGO HVLP gun |
Sounds like something has gone south inside, maybe a seal or blockage or ?? If you can't get a wet coat I'd suspect the mixture circuit. I've been using mine for years and it still works great. I know, probably not much help ![]() |
Author: | Mike OMelia [ Fri Mar 04, 2022 4:40 pm ] |
Ah. Found the problem. Air hole at top of container was blocked. |
Author: | Mike OMelia [ Fri Mar 04, 2022 4:41 pm ] |
Btw, ur the reason I own this gun. I love it. So easy to clean |
Author: | SteveSmith [ Fri Mar 04, 2022 5:14 pm ] |
Mike OMelia wrote: Ah. Found the problem. Air hole at top of container was blocked. Always good when it is something easy! |
Author: | Mike OMelia [ Sat Mar 05, 2022 12:04 am ] |
Can’t believe a blocked air hole stole a whole day. Lesson learned. |
Author: | SteveSmith [ Sat Mar 05, 2022 7:08 am ] |
It happens to all of us sometimes. |
Author: | Clay S. [ Sat Mar 05, 2022 9:53 am ] |
I use the cut off end of a guitar string to clear the air hole periodically. I twist a loop in it so I can hang it somewhere handy (sometimes on the gun). If I was more fastidious about my spray equipment it might not be necessary. |
Author: | SteveSmith [ Sat Mar 05, 2022 9:56 am ] |
I use the 3M PPS system so it's not an issue for me. The bladder that holds the finish collapses as you use it. |
Author: | ballbanjos [ Sat Mar 05, 2022 7:56 pm ] |
PPS is the way to go! Dave |
