| Official Luthiers Forum! https://luthiersforum.com/forum/ |
| Drum sander sandpaper https://luthiersforum.com/forum/viewtopic.php?f=10101&t=55185 |
| Author: | dofthesea [ Tue Aug 09, 2022 11:28 am ] |
| Post subject: | Drum sander sandpaper |
What is everyones preferred method for purchasing 16-32 sandpaper? Do you buy the precuts or do you buy the rolls and cut yourself? Whats the best quality? The sandpaper that is Jet branded and precut doesn't seem all that great. |
| Author: | doncaparker [ Tue Aug 09, 2022 11:40 am ] |
| Post subject: | Re: Drum sander sandpaper |
I buy the long rolls from Klingspor, with the colored lines on the back to signify where to cut, depending on which sander you have. It is boxed in Jet boxes. I would rather buy it that way than in individual rolls. If there are better brands, I would be interested. |
| Author: | bobgramann [ Tue Aug 09, 2022 11:46 am ] |
I buy the precut rolls for my Delta from Klingspor. I tried buying uncut rolls from elsewhere but quit when I decided the paper just wasn’t up to the quality I wanted—too many tears. I like the convenience of the precut rolls. They always fit and it’s a quick change. The cost is easily absorbed into what I charge for a guitar. |
| Author: | RogerHaggstrom [ Tue Aug 09, 2022 11:58 am ] |
I cut the new sandpaper using the old one as a template. Mirka Abranet is the best sandpaper for my drum sander. The net structure makes it less sensitive to oily woods like rosewood. I need to retention the papers now and then to keep it in place though, but that's not a big deal. https://www.amazon.com/Mirka-9A-570-080-Abranet-10yd-Mesh/dp/B004IQUICC/ref=sr_1_1?keywords=mirka+abranet+roll+80&qid=1660064164&s=industrial&sr=1-1-catcorr |
| Author: | meddlingfool [ Tue Aug 09, 2022 4:14 pm ] |
I buy rolls from a https://www.fintechabrasives.com/ The paper quality is good. I did buy a few precut Kingspor rolls once when i lost the thread on cutting my own and wanted a fresh template, and did not notice any demonstrable improvement. The fintech stuff is quite affordable, especially if you buy three packs… |
| Author: | bftobin [ Tue Aug 09, 2022 5:20 pm ] |
I bought a roll from Fintech based on Ed's recommendation and was more than satisfied. I cut it myself because there aren't many choices for a 18-38 sander. Before that I used Klingspor precut. |
| Author: | guitarjtb [ Tue Aug 09, 2022 8:02 pm ] |
I use the Mirka Gold PSA Autokut Roll, 2-3/4" x 20 yds, 80-grit MRK-23-574-080. The clips on my old Performax don't work so well, so I use the adhesive backed roll and use the one I remove as a pattern. |
| Author: | James Orr [ Tue Aug 09, 2022 9:52 pm ] |
I feel basic. I get the pre-cut rolls from Jet. Sent from my iPhone using Tapatalk |
| Author: | SteveSmith [ Wed Aug 10, 2022 6:15 am ] |
James Orr wrote: I feel basic. I get the pre-cut rolls from Jet. Sent from my iPhone using Tapatalk +1 Steve |
| Author: | guitarjtb [ Wed Aug 10, 2022 8:51 am ] |
James Orr wrote: I feel basic. I get the pre-cut rolls from Jet. Sent from my iPhone using Tapatalk Do you have a link for where you purchase yours? |
| Author: | SteveSmith [ Wed Aug 10, 2022 9:41 am ] |
I think the last ones I got came from Amazon. I believe you can also get them from Rockler and others. |
| Author: | doncaparker [ Wed Aug 10, 2022 11:43 am ] |
I looked at the math of large rolls vs. pre-cut. There is a small savings. For my sander (25"), $8.00 USD per wrap on the large rolls vs. $8.38 per wrap if pre-cut. I don't mind cutting the paper on the colored lines, and I like having lots of replacement paper on hand, so the larger rolls are better for me. Not a huge difference. I may have to look into the better types of paper, but for now, I consider it a consumable and don't worry too much about having to replace it when modest cleaning won't work. My drum is pretty easy to wrap. |
| Author: | Gary Davis [ Thu Aug 11, 2022 2:23 pm ] |
FYI-I just bought Jet rolls on Amazon. They were half price because the box was damaged. Look under "Used." I saved my old box for the new rolls. Gary Davis |
