Official Luthiers Forum! https://luthiersforum.com/forum/ |
Buffer speed https://luthiersforum.com/forum/viewtopic.php?f=10101&t=55234 |
Author: | CraigG [ Sat Sep 03, 2022 11:12 am ] |
Post subject: | Buffer speed |
I have a line on a Caswell 10 inch buffer. If it’s the one I think it is (waiting to hear from the seller) it’s lowest speed is 900 rpm. Is this still too high? I see that 715 is recommended Thanks, Craig |
Author: | bluescreek [ Sat Sep 03, 2022 11:16 am ] |
Post subject: | Re: Buffer speed |
I use a shop fox arbor with a 12 and 16 in buffing wheel a 1725 rpm 1/4 hp motor is all you need. Cotten flannel and domet wheels |
Author: | Bill Higgs [ Sat Sep 03, 2022 1:38 pm ] |
I use General Finishes High Performance Polyurethane and use 1100 rpm on a 10” wheel. Sent from my iPhone using Tapatalk |
Author: | Mike_P [ Sat Sep 03, 2022 3:56 pm ] |
I find this subject very confusing...or at least mysterious OK, so you've got a motor that has an rpm rating...fine...it's pulley interacts with another pulley on let's say the shop fox system...it would appear as if that pulley is larger than a motor pulley, so that steps down the rpm on the actual buffing wheels...then you've got the math behind the actual velocity of the buffing wheels...a larger diameter wheel is going to have more velocity than a smaller one, or put another way more of the buffing wheel is going to pass over the guitar per unit of time. so it seems to me making simple statements about rpms doesn't say much actually...horsepower would certainly be important as that defines how much you can bog down the motor (e.g. press the guitar harder against the wheel) from what I know of buffing using the type used on autos it's actually a pretty tricky proposition to get the perfect results, and what may really matter is becoming intimate with a specific system to know its in and outs and limits just my 2 pennies |
Author: | Mike OMelia [ Sat Sep 03, 2022 10:22 pm ] |
What John said, though my RPMs are a bit lower. What matters is torque. Too much, and ur guitar could end up in a pile of splinters on the floor. 1/4-1/3 hp max. I think my rpm is around 1000-1200. You should easily be able to stall the buffer with excess force. (Belt driven). I use a grisly arbor (fox) with a 1/3 hp motor. 3 14” canton flannel wheels on both sides. Normally, I have to physically hand spin it to get it going. I like that. |
Author: | joshnothing [ Sun Sep 04, 2022 2:42 am ] |
I have been running my shop built arbor at approximately 700rpm for years and despite it being “recommended” by some I feel like it’s actually kinda slow. Thinking of swapping out pulleys to speed it up a bit. I use a 1hp motor but a loose belt and can stall the wheels when I lean in. |
Author: | joshnothing [ Sun Sep 04, 2022 2:44 am ] |
Also, thinking of trying something more aggressive than flannel for the wheels too. Sent from my iPhone using Tapatalk |
Author: | Colin North [ Sun Sep 04, 2022 3:28 am ] |
What you should be looking at is the speed at the surface of your buffing wheel. And can depend on your finish too..... SM buffer details - Quote: Larger buffing surface: big 14" buffs, selected especially for instrument finishing. The right speed: slow 715-rpm buff speed is ideal for delicate instrument finishes. Driven by a powerful 3/4-horse motor. A smaller wheel would need a higher RPM. For the same speed with a 10" wheel as the SM buffer (14" wheel), the target speed is in inverse proportion to the diameter, this calculates - 14/10 x 715 = 1,001 RPM So I would say 900 RPM on your 10" wheel is a safe speed to try to see for "your" finish, certainly for nitro. If it's a tougher finish and/or buffing seems very slow, you should try a 12" wheel, which is 20% faster at the surface, would be better for heat dissipation and also clearance from the motor itself (shaft extenders are also available) or you could (maybe) up your speed a bit as it sounds like it's the variable speed buffer. |
Author: | bluescreek [ Sun Sep 04, 2022 5:35 am ] |
Colin is 100% correct its inch per min that is more important the rpm. also the stiffness of the buffing wheel so I use 2 cotten flannel and domet also the compound cakes I use 4 from menzerna polishing compound buffing compounds I use # 3 4 and ultra finish 175 however as good as the wheels are a buffing pad is also important I use a dual action buffer with 4 in pads I also use buffing and polish compound so it take a lot of learning to get that perfect finish. No buffer can compensate for poor prep work so be sure on a gloss finish A seal B fill C seal D finish application E Process F Technique so here is my finish schedule Seal I use recommended sealers by the manufacture Often Vinyl or shellac ( unwaxed flakes mixed in ever clear ) Filler most often I use aqua coat 3 applications Sealer I am a nitro guy so 4 to 6 coats 1 to 2 hour apart I keep my spray booth at 80 degree or higher there is a dehumidifier in the booth to maintain RH and air flow I use tape on the fretboard extension to measure build coats I want over .008 under .012 the dehumdifier allows level sanding in about 4 to 5 days you will know if your ready as the sand paper wont pill I use klingspore and assilex papers NOTE not all sand paper is the same you want a sand paper that is designed for finish work when leveling here is the part that was hard to fathom use 400 grit yes 400 grit you are doing finish in 2 parts build coats then finish coat so level sand with the 400 when done drop fill and touch up any weak point such as sinks or sand through now 3 coats of final finish this I will thin about 20% using a mix 75% thinner 25% retarder if the RH is low I may use less retarder heated to about 90 degrees Apply a good wet coat on the first coat again rest 2 hr between coats after 10 days level sand start with 1000 1200 1500 2000 then hand sand with assilex then buff again if you need to do drop fills do this after 2000 and drop fill I will then apply a coat on top of the drop fill this often cures up in a few days once leveled you can start buffing and polishing. I spend about 4 hr on final sand and buffing.. here is a tip on my sanding I use a festool sander at slowest setting use the sander like a trowel keep the weight at the training edge so you are leading on to the finish this helps the dust to clear and helps avoid swirls |
Author: | joshnothing [ Sun Sep 04, 2022 6:00 am ] |
Great tips and schedule John, thanks. Are the sandpaper grades you mention P or CAMI? |
Author: | bluescreek [ Sun Sep 04, 2022 6:52 am ] |
P It is also no hole I found that holes are gong to add to the swirl factor it can be used dry or wet I prefer dry on the initial level sand wet on final |
Author: | bcombs510 [ Sun Sep 04, 2022 10:22 am ] |
Regarding the caswell buffer, make sure to check the arbor diameter. I had one for a while and the arbor was 3/4” so I couldn’t use the wheels from SM, Jescar, etc.. Sent from my iPhone using Tapatalk Pro |
Author: | bluescreek [ Sun Sep 04, 2022 10:41 am ] |
Yes you can use those making an arbor shim is easy I get my wheels from Grizzly Jescar and creswell Making an arbor shim is as easy as wrapping it with solder or tape. |
Author: | bcombs510 [ Sun Sep 04, 2022 11:05 am ] |
I would not have guessed that wrapping tape would work. ![]() Either way I’m much happier now with the SM setup. Sent from my iPhone using Tapatalk Pro |
