| Official Luthiers Forum! https://luthiersforum.com/forum/ |
| SURVEY: Tuner Spacing https://luthiersforum.com/forum/viewtopic.php?f=10101&t=55471 |
| Author: | Chris Ensor [ Tue Jan 24, 2023 3:02 pm ] |
| Post subject: | SURVEY: Tuner Spacing |
2 questions: - How far apart do you space your tuners? - How far from the edge? Thanks in advance. |
| Author: | Mike Collins [ Tue Jan 24, 2023 3:11 pm ] |
| Post subject: | Re: SURVEY: Tuner Spacing |
for a steel string? Mike |
| Author: | Michaeldc [ Tue Jan 24, 2023 4:05 pm ] |
Generally, 1-1/2” apart north to south. On a 3 on a side head with straight sides (Martin) I do 1/2” on ADGB and 7/16” on E and E, like a Martin. Snake-head tuner edge spacing is 1/2” E to E. My drug of choice tuners for reference are Gotoh 510 minis. M |
| Author: | Trevor Gore [ Tue Jan 24, 2023 4:59 pm ] |
There are a lot of dependencies: Shape of buttons Shape/curvatures of the head stock Mounting square to the centreline or square to the headstock edge Straight-through string pull or not 6 string or 12 string Size/style of tuner body (open gear, sealed/cast body) etc. I asked the question of Hosco once, for a specific style of Gotoh tuner, as the drawing wasn't sufficiently dimensioned to be able to figure it out. Hosco referred the question to Gotoh, whose response was "we are not luthiers..." Basic rule: don't drill the tuner holes until you've had them in your hand. |
| Author: | Tim Mullin [ Tue Jan 24, 2023 5:24 pm ] |
I owned a Martin D35 and D12-28 when I started building. I designed my headstock shape starting with the Martin proportions and changed the top. The tuner spacing was also as for Martin, where the 1st and 6th are set in from the edge just a bit less than the others. Did the same thing for my 12s. Can provide exact measurements if someone really cares. Sent from my iPad using Tapatalk |
| Author: | Marcus [ Tue Jan 24, 2023 5:43 pm ] |
1.5" apart, 0.5" from the edge. |
| Author: | DennisK [ Tue Jan 24, 2023 6:18 pm ] |
1.25" apart, 0.5" from the edge. But 1.375" apart might be a better choice, because that appears to be the standard for 3-on-a-plate tuners. |
