https://luthiersforum.com/forum/
Teflon Strips
https://luthiersforum.com/forum/viewtopic.php?f=10101&t=55576
Author:  aulie2 [ Mon Mar 13, 2023 11:08 am ]
Post subject:  Teflon Strips
Does anybody know where to buy teflon strips in bulk for purflng beside NC Solutions? They can not ship for an unknown amount of time. Thanks.
Author:  mikeyb2 [ Mon Mar 13, 2023 11:53 am ]
Post subject:  Re: Teflon Strips
I had a problem getting these here in the UK a while back, so I bought some 2mm thick teflon sheet and cut strips of approximately 2.5mm on the bandsaw. Worked well, and cheaper as I recall. Just a thought. Mike
Author:  Alan Carruth [ Mon Mar 13, 2023 3:50 pm ]
These don't have to be Teflon; I've made no-stick strips out of polyethylene from old cutting boards. It jst has to be flexible, and not stick to water-based glues.
Author:  Clay S. [ Mon Mar 13, 2023 4:05 pm ]
Many people use UHMWPe strips rather than teflon. I got a piece several years ago from a skip that has served my needs for years, and recently my wife found a couple of cutting boards that were being tossed out that can also be sawed up into strips.
You can buy a 1/2 " X 6" X 36" piece of UHMWPe (commercial cutting board) from TAP plastics for about $25 that will make quite a number of strips: https://www.tapplastics.com/product/pla ... boards/346
Alternatively you can check if the local Walmart might have polyethylene plastic cutting boards in stock (or order a Farberware 11X14 poly cutting board from them for about $6) If you don't mind piecing strips in for purfling spacers.
Author:  Clay S. [ Mon Mar 13, 2023 4:14 pm ]
Looking closer at the email in your post, I'm guessing you are looking for strips all ready cut, rather than being a hobby builder looking at them for personal use?
Author:  Kbore [ Tue Mar 14, 2023 1:08 pm ]
Deleted; you're looking for bulk
Author:  Clay S. [ Tue Mar 14, 2023 5:18 pm ]
McMaster Carr sells sheets of the material, and if you can find a cabinet shop in Southern Maryland that has a powered laminate slitting machine they may be able to cut it into strips for a reasonable price.
