Official Luthiers Forum! https://luthiersforum.com/forum/ |
"Set" neck questions https://luthiersforum.com/forum/viewtopic.php?f=10123&t=39094 |
Author: | Sandywood [ Fri Jan 25, 2013 9:12 am ] |
Post subject: | "Set" neck questions |
Would making the pocket deeper for a Strat or Tele design be good enough or would it still need a tenon for strength? I have built one Tele style with a set neck and I did extend it. It seemed like most any benefit it may have had was removed by the pickup cavity. Not having to extend it with a tenon would sure make it easier as I usually use a top of figured wood. Thoughts appreciated. |
Author: | Sandywood [ Fri Jan 25, 2013 11:05 am ] |
Post subject: | Re: "Set" neck questions |
Thanks Chris. I couldn't find the thread but I did see two guitars at your site- "in progress" - that are good examples of why I'm questioning set necks. The photos are confusing to me because they show the neck extending past the fretboard and I don't understand. Is it trimmed off? Will the pocket be routered in body without the top on to fit the full length and then the top routered to fit around the neck/fretboard and then glued on? ( which is the way I did...it was very hard to get a perfect fit- the top fitting around the neck/fretboard...but I did and the reason I'm looking for an easier way- just seemed wrong) I was also questoned about this when I saw the neck setting alignment jig. It also showed the neck with tenon and I just couldn't believe the glued on figured top would be routered away for that tenon...I'm missing something. |
Author: | dzsmith [ Sat Jan 26, 2013 4:54 pm ] |
I've built several where I chppoed the neck off at the end of the fretboard, with no extra tenon. I think it depends how far into the body the neck will go. Mine were around 3". I'm building a new one now, and I have the end of the fretboard about 1/2" past the edge of the body, so I'll have to use an extended tenon, and then go through the chore of making the top plate match as you did. Dan |
Author: | Sandywood [ Sun Jan 27, 2013 9:52 am ] |
Dan I found one thing that will make it easier for me- in Frank Cousins thread about the bass fretboard. Having the oversized top. The first one I did had the top and body sized and the one I'm working on now does. The next one won't. |
Author: | Sandywood [ Sun Jan 27, 2013 12:26 pm ] |
Thank you Chris. The pictures are fine examples. I have a better understanding of variations and why. I installed P-90s that I wound so I had top inbetween the fretboard and pup-had I not trimmed the top to body I would have had some play for getting the top/neck fit easier. |
Author: | Chameleon [ Tue Jan 29, 2013 9:36 pm ] |
verhoevenc wrote: Between these two pics you can KINDA see the pocket and how tiny you can get away with if you need to: ![]() ![]() Can't believe I don't have a straight on picture of that pocket?! That neck ended AT the fretboard. My other necks extend past it in my electrics. The reason? I'm routing a pickup right after the neck... who cares if there's a tenon. I set it and the humbucker goes in right over the extra tenon length. And in most cases the tenon is deeper than a pickup route, so I get that added extra support into the body (whether I need it or not, it's nice). Chris Thanks for the encouragement. I'm doing a bass with a similar kind of cutaway, although the pocket is longer and deeper. It will also end at the fretboard. |
Author: | Brett L Faust [ Fri Mar 22, 2013 10:55 pm ] |
I have made set necks out of "bolt on style parts" that were a very tight perfect fit,( I could lift the guitar by the neck with no glue yet). Hint, chamfer the tenon corners inside the joint so the glue has a place to go(hydraulic pressure can prevent proper seating). 10 years old now, without a hint of joint trouble. |
