https://luthiersforum.com/forum/
Custom ES335 Style build
https://luthiersforum.com/forum/viewtopic.php?f=10123&t=39106
Author:  Irving [ Sat Jan 26, 2013 10:37 pm ]
Post subject:  Custom ES335 Style build
Built this for a friend to his personal specifications. This is my 12th build and my best playing guitar yet.
Thought I would share a series of construction shots as well as a few of the final result.
Author:  Chris Pile [ Sat Jan 26, 2013 11:50 pm ]
Post subject:  Re: Custom ES335 Style build
Gorgeous! I love it.
Author:  Tony_in_NYC [ Sun Jan 27, 2013 7:46 am ]
Beautiful. What is the finish?
Posted using something.
Author:  cphanna [ Sun Jan 27, 2013 11:33 am ]
James, that's a great looking guitar and I love the color. My personal preference would have been for filled, level pores on the body, but that's not meant as a criticism. Have you weighed it? I suspect it's heavier than a 335, but lighter than a Les Paul. I'm not knocking weight, either, I'm just curious. Did you carve out the inside of the top on either side of the center block? It appears you might have. I've always liked this general style of guitar--more so than smaller solid bodies. I think your instrument is very, very nice overall. Makes me want to pick it up and try it out!
Patrick
Author:  Irving [ Sun Jan 27, 2013 12:19 pm ]
Thanks for the feedback. The grain was left unfilled and I used StewMac colortone dye diluted with water. I then applied a mere 8 coats of tru oil. The lack of grain filling and extensive finish coats was due to the amount of money I charged my friend/customer and he was just fine with having a natural wood feel and open pores. I have done 10 nitro finishes and this was my first tru oil finish. So it was good to try something else. It's a thin finished guitar but I feel confident it will last a long time.
Author:  dzsmith [ Sun Jan 27, 2013 1:14 pm ]
James,
That is a great looking axe!
The binding really makes the color pop.
I dig the unfilled grain and the finish.
Forgive my ignorance, but what material did you use for the neck and body?
Dan
Author:  Irving [ Sun Jan 27, 2013 5:52 pm ]
The body and top are ash.
The neck is cherry and the fretboard is Pau Ferro.
24.9" scale length with 24 frets.
Author:  hugh.evans [ Mon Jan 28, 2013 2:34 pm ]
Nice build. I like the no-frills look of it much more than I would have anticipated. One question: What's the story with the three dowels under the neck pocket? Nothing wrong with it, but it's driving me crazy trying to figure out if you used screws for positioning/clamping and then filled the holes later or just used dowels for positioning (since I see clamps were used during the glue up.) Very curious to know what they're there for. Both possibilities sound like solid ideas.
Again, congrats on a great looking build!
Author:  Irving [ Mon Jan 28, 2013 5:34 pm ]
Thank you sir! The three wooden plugs cover 3 inlaid bolts. The neck joints that I do are most similar to PRS style set necks and there is indeed tightbond in there which is probably more than enough for strength. I then go the extra mile and put 3 bolts into the heel - inlaid nicely under wooden plugs. Just trying to give absolute maximum strength. I think that it also helps to set my neck joints apart from the rest.
Author:  James T [ Tue Feb 12, 2013 1:09 pm ]
Very nice work indeed .
Author:  GourmetSaint [ Fri Apr 05, 2013 8:05 pm ]
Beautiful work. I've started a similar project using Tasmanian Blackwood and am planning on using a red dye too but will finish with hard shellac.
Sent from my GT-I9100 using Tapatalk 2
Author:  Mike Baker [ Sun Apr 07, 2013 7:43 am ]
That's lovely work! Now I wanna build one of those!
Author:  GourmetSaint [ Wed Apr 17, 2013 10:42 pm ]
Great job. Couple of questions. What do you think of not extending the solid centre all the way through. Ie stop short below level of stop piece. More carving and lighter vs acoustics?
Noticed the lead socket not on front as per original. Conscious choice? Gibson moved socket in other ES models after feedback from outside 335 players. Thoughts?
Author:  Sandywood [ Thu Apr 18, 2013 7:38 am ]
Man that is sweet. It screams to be played.
Author:  Tomyyy [ Thu Oct 03, 2013 8:58 pm ]
Really nice project! What is the neck angle?
Author:  Mike Baker [ Fri Oct 04, 2013 6:52 pm ]
Is there any carve to the top or back of this guitar? It all looks flat to me.
It's lovely, whichever way it is.
Author:  Bjornstad [ Sun Oct 06, 2013 3:35 pm ]
Thank you. Great work. Very inspiring.
Author:  James T [ Tue Oct 08, 2013 8:16 pm ]
VERY nice work , inspiring to be sure!
