Official Luthiers Forum! https://luthiersforum.com/forum/ |
Wiring quandary https://luthiersforum.com/forum/viewtopic.php?f=10123&t=40255 |
Author: | Chris Pile [ Fri May 03, 2013 11:22 pm ] |
Post subject: | Re: Wiring quandary |
Is that a picture of a 5 position switch? And is that what you used? |
Author: | Dekka [ Sat May 04, 2013 3:41 am ] |
Filippo you should ask Deaf Eddie as it is one of his schematics. He has helped me out heaps. But for what it is worth I am seeing a complete Series OOP circuit in pos 4....Back-tracking from the jack, the hot goes from the jack-tip to the volume pot then from the volume pot through a dog-leg of red lugs to the negative of the neck pup... then through the neck coil and out the black lead to meet the blue lugs that then mates with a common lug shared by the bridge pup positive lead and the bridge tone-pot. |
Author: | StevenWheeler [ Sat May 04, 2013 12:09 pm ] |
Filippo, I like the wiring diagrams from GuitarElectronics.com better than most. Try this link http://www.guitarelectronics.com/product/WD2HH5L12_05/Guitar-Wiring-Diagram-2-Humbuckers5-Way-Lever-Switch1-Volume2-Tones-05.html and see if this diagram will work for you. |
Author: | Dekka [ Sat May 04, 2013 3:00 pm ] |
You need to check that the hot side of the circuit is not shunting to ground. Most likely it's small blob of solder shorting across pos4 somewhere. Using your multi-meter, back-track from the hot side, ie, jack tip, and find where ground occurs. One other question...Have you created a seperate shield ground on the single coil pickups? |
Author: | Dekka [ Sun May 05, 2013 12:35 am ] |
Quote: Pardon my ignorance, Derek. What would be a separate shield ground? Aside from the diagram I posted, the only additional wiring I have is the bridge post to the back of one of the tone pots. Filippo If you were using a tele neck pup, for instance, you must disconnect the ground wire from the cover and run a separate shield wire to achieve the coil's lift from ground in the series connection. |
Author: | nutsdan [ Sun May 05, 2013 12:50 am ] |
Do the pickups cables have 2 cores and a shield or are they vintage gibson style with 1 core and a mesh shield? |
Author: | StevenWheeler [ Sun May 05, 2013 8:52 pm ] |
I linked the wrong diagram, sorry for the confusion. The one I meant to link was also a four conductor but is very close to what Chris posted. After reviewing the Tele diagram, I believe this is the correct one to use once you get the pickup leads squared away. |
Author: | nutsdan [ Sun May 05, 2013 10:46 pm ] |
with the gibson wire and the 2 shields touching as soon as the switch goes to reverse the phase it means that the switch puts the+ to earth and the shield earths to the bridge shield, therefore no output. |
Author: | nutsdan [ Sun May 05, 2013 10:48 pm ] |
The best solution is to shield the whole cable with heatshrink to prevent the cables from earthing each other |
Author: | Dekka [ Sun May 12, 2013 1:44 am ] |
That's more or less what I meant, Filippo. I'm sorry that I didn't explain it better earlier and save you some angst. I just didn't have it in my head that you were using single wire with the outer sheathe of shielding. Glad you got there in the end though. |
Author: | Tony_in_NYC [ Tue May 14, 2013 2:51 pm ] |
You gotta get all of that spaghetti out of the guitar. And those knobs and switches. Hollow it out and thin the soundboard. Then you'll have a decent guitar. ![]() |
Author: | dzsmith [ Tue May 14, 2013 6:38 pm ] |
Tony_in_NYC wrote: You gotta get all of that spaghetti out of the guitar. And those knobs and switches. Hollow it out and thin the soundboard. Then you'll have a decent guitar. ![]() Yeah, but can you still play Smoke on the Water on it? |
Author: | Tony_in_NYC [ Wed May 15, 2013 12:03 am ] |
Well of course. Just a slightly less loud version and without distortion. |
