https://luthiersforum.com/forum/
How would you cut this tenon?
https://luthiersforum.com/forum/viewtopic.php?f=10123&t=41575
Author:  MetalOne72 [ Fri Oct 04, 2013 3:26 pm ]
Post subject:  How would you cut this tenon?
I was doing some looking around on the net and came across this picture of a Kenneth Lawrence Explorer and was puzzled on how you would go about cutting this tennon. It looks like the fretboard extension is not wings and is cut into the neck blank. My best guess is that it is routed from the underside (bottom of the heel) so that the router bit curvature is between the tenon and the face that butts against the body. Any other guesses?
Author:  Cush [ Fri Oct 04, 2013 5:53 pm ]
Post subject:  Re: How would you cut this tenon?
It could be routed as you suggest. If the builder had a mini milling machine that would get the job done quickly. I have made similar neck joints using my mini mill. It is one of my most favored power tools. There are probably many ways to do this, so the best way to find the answer is to ask the maker.
Author:  klooker [ Sat Oct 05, 2013 2:09 pm ]
I'd say route from underneath like you suggest then chisel out the one inside corner that's rounded because of the router bit.
Kevin Looker
Author:  the Padma [ Sat Oct 05, 2013 3:53 pm ]
The tenon was cut first, with any number of different saws...take your pick and then the extension was planted added on at about the 18~19...now that may just be a pencil mark, if so ...any one of the above answers would do it including a chisel.
blessings
duh?adma
