Official Luthiers Forum! https://luthiersforum.com/forum/ |
Fender TBX tone control https://luthiersforum.com/forum/viewtopic.php?f=10123&t=43965 |
Author: | Van Savage [ Sun Aug 10, 2014 10:29 pm ] |
Post subject: | Fender TBX tone control |
I built a guitar with Lace Sensor Duallys, splitted them with miniswitches and used a TBX tone control. Everything works according to plan except the TBX. When I turn it up past the detent into treble it makes a pretty wicked hum. Any help or tips will be much appreciated. Cheers, Van |
Author: | Chris Pile [ Sun Aug 10, 2014 11:37 pm ] |
Post subject: | Re: Fender TBX tone control |
When they are split, they are single coils. And single coils hum. |
Author: | Van Savage [ Wed Aug 13, 2014 10:01 pm ] |
It makes a high pitched hum regardless of whether they're split or in dual mode. |
Author: | Chris Pile [ Wed Aug 13, 2014 11:22 pm ] |
Quote: It makes a high pitched hum regardless of whether they're split or in dual mode. Then you have other problems. Is it grounded? |
Author: | mechanix [ Thu Aug 14, 2014 7:43 am ] |
Sounds like an earth problem. I fitted one to a 90s strat years ago and had a similar problem. That turned out to be a broken wire. Using a multimeter check for continuity between all your grounds and bridge ect. I'll bet one is of high resistance or broken/missing, the tbx pot shouldnt cause a problem itself, its just two pots in one that switch over at pos5. Double check your wiring against the diagram too. Is it a fender made tbx? |
Author: | Van Savage [ Thu Aug 14, 2014 9:29 pm ] |
Thanks for the photo and all the suggestions. Yes, it is a Fender TBX and yes, I will get busy with it this weekend. My soldering leaves much to be desired and my glob of ground wires soldered to the vol. pot are a mess. Maybe I'll pull them loose and do it again for the third time. Thanks again. |
