| Official Luthiers Forum! https://luthiersforum.com/forum/ |
| Wiring https://luthiersforum.com/forum/viewtopic.php?f=10123&t=57679 |
| Author: | Mayco05 [ Thu Apr 09, 2026 8:35 am ] |
| Post subject: | Wiring |
Hello, just wondering if there are any downsides (besides price) to using solder-less wiring harnesses, like mojo tone or obsidian? Sent from my iPhone using Tapatalk |
| Author: | rbuddy [ Fri Apr 10, 2026 3:24 pm ] |
| Post subject: | Re: Wiring |
I haven't used the MojoTone solderless system but in general, electrical connections have improved a lot over the last couple decades. A lot of house and commercial wiring is now done with "push-on" type connectors and they work pretty well. Looks like Mojotone is a company that takes a lot of pride in their work so I think you'll be fine if that's what you are considering. It is hard to beat solder though. And in something like a guitar that's moved around a lot there are advantages to solder. Soldering isn't difficult as long as you follow basic rules and it is a good skill to learn. Lots of excellent youtube videos on good solder techniques. A couple hours of practice and you should have it down. |
| Author: | Mayco05 [ Wed Apr 15, 2026 2:15 pm ] |
I really appreciate the response and the info. And I totally agree that soldering is a must for electric guitar/bass building, i’m still working on it but I can’t seem to get the hang of it. I was just curious how it would hold up overtime and with travel, and you answered that for me thank you! It was what I thought “it works but not as good as a well done solder connection” Sent from my iPhone using Tapatalk |
| Author: | Durero [ Thu Apr 16, 2026 10:29 am ] |
Solderless guitar wiring systems have been around for about 50 years. Any EMG system has solderless connections, as well as numerous active bass pre-amps. There are significant advantages to solderless connections in terms of flexibility, component swapping, and troubleshooting. I think you should use whichever you prefer. If anyone tells you they can hear a difference between soldered and solderless connections they're engaging in magical thinking. The effectiveness of any connection can be easily tested by taking a multi-meter and measuring the resistance across the connection. Soldering skills are certainly also good to learn. There is a great soldering basics course available on LinkedIn Learning: https://www.linkedin.com/learning/learning-soldering-for-electronics Where I live, we get free access to LinkedIn Learning through our public library. I'd recommend checking to see if that's the case in your area too. |
| Author: | Freeman [ Fri Apr 17, 2026 12:24 pm ] |
I have mounted small terminal strips in the pickup cavities of semi hollow body guitar for splicing the pickup wires. It makes wiring much easier than fishing everything out thru the f-holes particularly if you wanted to change pickups. Everything else I solder. |
