Official Luthiers Forum! https://luthiersforum.com/forum/ |
Steve Wheeler's Challenge Build https://luthiersforum.com/forum/viewtopic.php?f=10133&t=37324 |
Page 5 of 6 |
Author: | StevenWheeler [ Fri Oct 19, 2012 6:43 pm ] |
Post subject: | Re: Steve Wheeler's Challenge Build |
While the glue was drying I took the front piece to the thickness sander. Attachment: cajon 003.JPG Ran it through until it was about .100 thick. I was thinking about using this for the face, but I did'n't. Attachment: cajon 004.JPG
Author: | StevenWheeler [ Fri Oct 19, 2012 6:52 pm ] |
Next up was gluing and nailing the snare supports to the box. Attachment: cajon 017.JPG Screws attach the snare in the upper left corner. Attachment: cajon 019.JPG Another block of plywood to mount the dowel rod and a J-slot. When the dowel is moved to the catch of the slot, it pulls the snare off the skin. Attachment: cajon 021.JPG Last for today, glue the face and back on. Attachment: cajon 022.JPG
Author: | Beth Mayer [ Fri Oct 19, 2012 11:34 pm ] |
Steve, I really want to build a Cajone sometime! You make it look easy, but I doubt it is. |
Author: | StevenWheeler [ Sat Oct 20, 2012 6:33 am ] |
Here is a site with a tutorial for you Beth. http://www.thecajondrumshop.com/index.php?page=How-To-Build-A-Cajon |
Author: | Beth Mayer [ Sat Oct 20, 2012 8:44 am ] |
Thanks Steven! |
Author: | StevenWheeler [ Sat Oct 20, 2012 2:00 pm ] |
I forgot the camera today. The drum is now all routed, sanded and the first coat of poly applied. |
Author: | StevenWheeler [ Wed Oct 31, 2012 8:39 pm ] |
I finally remembered to charge the camera. Here is the Cajon all finished. Attachment: cajon 002.JPG Attachment: cajon 003.JPG I blocked out the finish on the jazz mando and the bari uke with 800 grit last week. I'll be finishing up wet sanding those tomorrow or Friday and then off to my friend Johns this weekend to use his buffer. The mando bridge was fitted to the top on Monday. I should have the time to have both of these playable by next weekend. |
Author: | Beth Mayer [ Thu Nov 01, 2012 9:49 am ] |
You're kind of an overachiever Seriously, that Cajon is really cool! Can't wait to see the entire band all together. |
Author: | StevenWheeler [ Tue Nov 06, 2012 9:32 pm ] |
This afternoons rain canceled my income producing plans, so I got in some shop time. Nothing exciting, just the wet sanding that I was going to do last week. All blocked out with 1000 grit now, tomorrow is 1200 grit then reschedule that date with John's buffer. Steve |
Author: | Bryan Bear [ Tue Nov 06, 2012 10:18 pm ] |
I'm really looking forward to seeing all of them together and completed. Your prolific production humbles me. |
Author: | Tony_in_NYC [ Tue Nov 06, 2012 10:23 pm ] |
If you make a multi-track recording of all of the instruments together, you win my vote. |
Author: | StevenWheeler [ Wed Nov 07, 2012 3:21 pm ] |
Bryan Bear wrote: Your prolific production humbles me. Just keeping myself busy. The devil makes work for idle hands, and I'm trying to stay off his payroll. |
Tony_in_NYC wrote: If you make a multi-track recording of all of the instruments together, you win my vote. How about a live jam session? |
Author: | StevenWheeler [ Wed Nov 07, 2012 3:31 pm ] |
These tuners were cheap and the white pearloid buttons really accentuate the look. A chunk of ebony that was left over from making fret boards, bridge blanks and head plates is going to help us out here. Attachment: Challange Mandolin 001.JPG Cut some suitably sized pieces on the table saw. Attachment: Challange Mandolin 002.JPG A 3/4" hole saw will work as a plug cutter to net some 5/8" slugs. Attachment: Challange Mandolin 003.JPG Attachment: Challange Mandolin 004.JPG I use a piece of drywall to mark the grain direction. Attachment: Challange Mandolin 005.JPG
Author: | StevenWheeler [ Wed Nov 07, 2012 3:49 pm ] |
I used my cheap but useful Harbor Freight cross vise to line up the slugs and drill a 1/8" hole for the shaft. The tuner shaft requires a 9/64" hole but this is the closest size brad point that I own. I open up the hole to final size after shaping. Attachment: Challange Mandolin 006.JPG A 2 1/4" #6 wood screw lightly started into the tuner shaft hole makes a good enough handle to hold the button for shaping on the edge sander. Attachment: Challange Mandolin 007.JPG Attachment: Challange Mandolin 009.JPG Attachment: Challange Mandolin 010.JPG Only lost one to the screw. Perhaps drilling the hole cross grain would have been more prudent. |
Author: | StevenWheeler [ Wed Nov 07, 2012 4:02 pm ] |
A soldering gun heats up the shaft to soften the plastic buttons which are pulled off with pliers. Attachment: Challange Mandolin 012.JPG No pics of sanding, enlarging the shaft holes in the buttons or pressing them on to the shafts using the vice. Even more non pics of super gluing a crack in one button, replacing the other more severly cracked button or wiping on a coat of thin CA with a smoking paper towel. We do however have a final picture of the much more attractive re-buttoned tuners fit for a Jazz Mandolin. |
Author: | SteveSmith [ Wed Nov 07, 2012 4:28 pm ] |
The ebony tuner buttons are a huge improvement |
Author: | Beth Mayer [ Wed Nov 07, 2012 4:29 pm ] |
Loved the detail on the tuner buttons! If they're just pressed on, what keeps them from slipping when bringing strings up to pitch? |
Author: | StevenWheeler [ Wed Nov 07, 2012 9:00 pm ] |
Beth Mayer wrote: Loved the detail on the tuner buttons! If they're just pressed on, what keeps them from slipping when bringing strings up to pitch? Thanks Beth The buttons are secured to the shafts with a prodigious amount of medium CA. |
Author: | StevenWheeler [ Wed Nov 07, 2012 9:04 pm ] |
SteveSmith wrote: The ebony tuner buttons are a huge improvement Thanks Steve, I was quite happy they were such a simple shape, easier to duplicate than most. |
Author: | Bryan Bear [ Wed Nov 07, 2012 10:26 pm ] |
Great job on the buttons. I'm glad I saw this, it contributed to one of those "well " moments. For a long time I have been wanting to set up to be able to make tuner buttons that matched my fretboards. I have not gotten around to it, mostly because I have not figured out how to shape the buttons. Just last night I was noticing how crappy the plastic buttons on my economy mandolin tuners looked. It never occurred to me that mando buttons can be little circles. I have scraps of my fretboard wood and an extra month to work with, I may have to try this. |
Author: | StevenWheeler [ Sun Nov 11, 2012 7:17 pm ] |
Shiney time. This is why I go to John's shop to buff. A nice Stew Mac buffer set up with plenty of natural light for checking your progress. Attachment: Challange Mandolin 002.JPG Pull 1 buff off each side to get into those tight cutaways and waists. Attachment: Challange Mandolin 006.JPG A picture of John's back yard. Attachment: Challange Mandolin 003.JPG This is his fire extinguisher. Attachment: Challange Mandolin 007.JPG I really like the trans red on the previously crappy looking hemlock. Attachment: Challange Mandolin 008.JPG
Author: | Tony_in_NYC [ Mon Nov 12, 2012 6:55 am ] |
Post subject: | Steve Wheeler's Challenge Build |
Mmmmm...shiny. Posted using two tin cans and some string. |
Author: | StevenWheeler [ Wed Nov 14, 2012 10:08 pm ] |
A bit of assembly this afternoon. |
Author: | Beth Mayer [ Wed Nov 14, 2012 10:20 pm ] |
Okay Steve, I want to buy that black beauty!!!! LOVE IT |
Page 5 of 6 | All times are UTC - 5 hours |
