| Official Luthiers Forum! https://luthiersforum.com/forum/ |
| Gallery of shame https://luthiersforum.com/forum/viewtopic.php?f=10137&t=54537 |
| Author: | joshnothing [ Sun Nov 14, 2021 7:00 pm ] |
| Post subject: | Gallery of shame |
As a complement to our “Dumb things customers say”, I thought we could maybe have a thread for the dumb, ugly or just pain head-scratching things manufacturers do. Here’s a one out of a LAG dread in for a bridge reglue. A jaunty angle for the cap on the x-brace: ![]() You gotta wonder how fast they’re slapping these things together. |
| Author: | Chris Pile [ Sun Nov 14, 2021 7:14 pm ] |
| Post subject: | Re: Gallery of shame |
I like all the loose cotton... |
| Author: | Smylight [ Sun Nov 14, 2021 7:45 pm ] |
I could go in for quite some time about the 1966 Gibson LG-0 that's currently on my desk, but I suppose y’all already know all about this… Pierre Guitares Torvisse |
| Author: | Freeman [ Mon Nov 15, 2021 12:04 pm ] |
Here is an absolutely brand new Fender acoustic 12 string. It was hanging on the wall of my local music store when the bridge came off. Still has the protective sheet on the pick guard. Attachment: IMG_4533.JPG The bridge had been glued directly to the catalyze poly finish. When asked about covering it under warranty Fender refused and said "thats the way we make them". I fixed it, the store sold it at a loss with full disclosure. Unfortunately I have had two other Fender bridge failures cross my bench. |
| Author: | Chris Pile [ Mon Nov 15, 2021 2:20 pm ] |
Wow. I used to be an authorized Fender repair guy, and would have been pretty upset with a reply from them like that. Times have changed.... |
| Author: | joshnothing [ Mon Dec 06, 2021 10:02 pm ] |
This isn’t shameful, just … curious? A circa 2010s National El Trovador in for a setup. There appears to be removed and plugged dot inlays at 15/17/19th frets. Bit of googling and this model indeed normally has no inlays above the 12th. Factory must have been trying to use up boards from another model or something. Apologies for the greasy appearance of the fb - I was midway through oiling it when I noticed the plugs. Since it’s ebony the plugs are essentially invisible unless there’s something greasy on there to show them up.
| Author: | DanKirkland [ Tue Dec 07, 2021 11:49 am ] |
That's probably to hide the screw heads from where the board is attached to the body? |
| Author: | joshnothing [ Tue Dec 07, 2021 2:46 pm ] |
DanKirkland wrote: That's probably to hide the screw heads from where the board is attached to the body? That’s interesting - I didn’t realise these were screwed on. I don’t see many resonators come through the shop so my experience is limited. The configuration and size of the plugs (double dot, single, double) as well as being at 15th, 17th, 19th etc just had me thinking “position markers” straight away. I have to pull the cone out today to mess with the pickup wiring so I’ll have a look on the inside. |
| Author: | Chris Pile [ Tue Dec 07, 2021 4:51 pm ] |
Having worked on a couple resonator guitars, I can tell you it's screws underneath. Many makers just put pearl dots there. I hate working on resonators about as much as I hate working on banjos. Compared to normal guitars, they are just plain weird. |
| Author: | joshnothing [ Tue Dec 07, 2021 5:43 pm ] |
Makes sense, thanks Dan and Chris. They're not my favourite patient either, it's a little tedious taking them apart to get the biscuit out, do some work, reassemble, restring, test, disassemble, tweak, reassemble etc. |
| Author: | joshnothing [ Tue Jul 05, 2022 6:40 pm ] |
There has been some talk in the past about how factories don’t do a great job of using all available gluing surface when they attach a bridge. What about other glue joints on a guitar? Here’s one courtesy of Martin & Co. ![]() Yes, the fretboard fell off on its own. I think there was a stiff breeze that day. |
| Author: | Chris Pile [ Tue Jul 05, 2022 7:54 pm ] |
Someone did not make an effort... |
| Author: | Hesh [ Wed Jul 06, 2022 2:23 am ] |
That's a very low end Mexican Martin, not their best foot forward or how I would judge Martin's work. |
| Author: | joshnothing [ Wed Jul 06, 2022 4:57 am ] |
It’s a low end one for sure but the soundhole label says “Made in USA” - I believe this one dates from the period that the HPL axes were made in Nazareth. So this one ain’t on Mexico I think cost savings for budget models should come from cheaper materials, simplified bracing, omitting binding etc. Assembly of critical components is not where they should be squeezing pennies. That said, this could just be one lazy guy with a bottle of titebond trying to get out the door quick on a Friday afternoon, rather than official procedure. But still, it was built in their factory by their staff and they stuck their name on the headstock, so no pass for Martin from me on this one. |
| Author: | WudWerkr [ Wed Jul 06, 2022 8:36 am ] |
Rebuilt a 70's Gretsch Country Gentleman. I took off the Back Pad that snaps on and found what appears to be the electronics access was cut with a Jig saw free hand . Apparently from the factory ? I was not Impressed After working on this guitar I am not a fan of Gretsch Guitars . Attachment: gretsch 3.jpg
| Author: | Barry Daniels [ Wed Jul 06, 2022 10:39 am ] |
The inside of Gretschs were made a bit rough. |
