It is currently Tue Jul 29, 2025 3:29 pm
 Post subject: Abalone Help
PostPosted: Fri Feb 22, 2008 5:30 pm
I've got a customer that wants ablam rosette and purflings comparable to those on a taylor presentation series. Can someone tell me which type of Ablam they're using and how wide the rosette is?
Thanks, Don
Don Sharp
Got Brazilian?
http://www.sharpguitars.com
 Post subject: Re: Abalone Help
PostPosted: Fri Feb 22, 2008 5:43 pm
I believe they are using .063" wide Paua for the purfling and the rosette. I am afraid that unless you want to cut your own rosette ring you will be limited to 4.921 ID rosette ring segments The good news is I believe this is what Taylor uses I know for a fact that most Taylor guitars with abalone purfling and rosettes they use green ablam but I think I recall on presentation models they were much blue-er in color and that would be the Paua.
PostPosted: Fri Feb 22, 2008 5:48 pm
Thanks.
I typically use .063 for my purflings and rosettes. The rosettes look much wider to me.
Don Sharp
Got Brazilian?
PostPosted: Fri Feb 22, 2008 5:51 pm
I just did some checking and I am right on every thing but the rosette They are using 1/4" wide on the rosette. That is available and through Rescue Pearl and some other vendors. Here again the circle ID of the ablam will be 4.921" There is not much different her than Martin D45 purfling other than the wide rosette.
Check out Taylor's web site/accoustics/presentations models they have several pictures from several angles
one of the pictures looked a bit like Red ablam so I bet they use what ever exceptional pieces of Paua or Red they have on hand at the time
PostPosted: Fri Feb 22, 2008 9:34 pm
Thanks, I've seen the pics. Just wasn't sure about the rosette and where to get it. I've checked several places (Duke of Pearl, Rescue Pearl, etc.) and only find it up to .135" wide. I may have to cut it myself.
Don Sharp
Got Brazilian?
PostPosted: Sat Feb 23, 2008 12:13 am
Check out Australian Mother of Pearl Co. who is a sponsor. They will custom cut for you and the service is terrific.
PostPosted: Mon Feb 25, 2008 6:52 am
+1
Had them do some thinner rings for rosettes, have enough to last me a decade or two now, and the price and service were great.
Users browsing this forum: mcgr40 and 15 guests
