It is currently Mon Jul 28, 2025 11:37 am
PostPosted: Tue Mar 18, 2008 7:26 am
I know some of you use Z-poxy or other similar materials to fill pores. I have been using pumice and shellac, but would like try epoxy. Do you have any surface preparation tips?. Are there issues with color bleeding out of EIR onto the lines?, Should I perhaps seal the lines first with shellac?
Regards
PostPosted: Tue Mar 18, 2008 7:38 am
Mark buddy when we speak of using Z-Poxy for pore filling just be sure that you are using Z-Poxy "finishing resin" and not the several other Z-Poxy varieties of epoxy glue.
Shellac will stick fine to epoxy/Z-poxy but epoxy will not stick well to shellac. So do not seal anything with shellac that you plan on filling later with epoxy.
In my experience Z-Poxy does not cause rosewood oils/colors to bleed. Just use the Z-poxy as you would use shellac to seal what needs to be sealed. Some of us will do a final 50/50 coat of Z-poxy and denatured alcohol wiped on with a lint free rag to even out color and completely seal the guitar.
PostPosted: Tue Mar 18, 2008 8:01 am
hesh nailed it.
PostPosted: Tue Mar 18, 2008 9:55 am
Last Name: Sollod
I have had z-poxy cause cocobolo in a rosette to bleed...
www.swiftcreekguitars.com
PostPosted: Tue Mar 18, 2008 2:36 pm
Thanks Hesh - I will get the finishing epoxy and I will use it to seal all lines, binding and back/sides prior to proceeding to shellac French polish.
Thanks again!
PostPosted: Tue Mar 18, 2008 5:14 pm
I've been doing just that for years without any problems.
PostPosted: Tue Mar 18, 2008 5:54 pm
I'm sorry, I thought Hesh was talking about filling. I'm not finishing, I'm pore filling. I use a washcoat of dewaxed shellac, fill with old fashioned hardware store 5 minute epoxy, and when it's cured I scrape and sand back to the wood. Never saw the fill fall out of a pore.
Users browsing this forum: Kbore and 10 guests
