It is currently Thu Jul 24, 2025 7:21 pm
PostPosted: Mon Jun 23, 2008 8:23 pm
I'm looking for suggestions on cook times and temperature for bending walnut on a fox bender. Or any other tips or tricks which may be helpful.
Chris
PostPosted: Tue Jun 24, 2008 6:00 am
Chris buddy Claro is one of he easier woods to bend. I never measure my temps, doing it by feel, but I would suspect that it bends at the lower temps like 290ish. I lightly spritz with distilled water, wrap in foil or craft paper, craft paper is probably better, and it bends like butter.
In fact I believe that Claro was the easiest wood that I ever bent.
Also - highly figured woods add complexity and difficulty to the bend, is your set highly figured? If so go slightly hotter and consider using a product like SuperSoft II prior to bending.
PostPosted: Tue Jun 24, 2008 6:12 am
Hi Chris, I've never bent any walnut but welcome! Nice to see you over here as well.
PostPosted: Tue Jun 24, 2008 6:34 am
Thanks Arnt I didn't notice that Chris is a new member - Welcome Chris! [:Y:] [clap] [clap] [clap]
PostPosted: Tue Jun 24, 2008 8:40 am
Thanks for the information. There's some figure to it as far as some fiddle back at places.I could post a picture of a set but I'm not familiar with the software over here yet. There is a picture of the back set that was cut from the same board over at MIMF in a Re Saw discussion. I have the sides sanded down to .090"-.085" and the backs from .115", 2-.110" and .100". I plan on bending the a set of sides within the next couple of days. It will be the first sides I've bent, well the first set of wood sides.
PostPosted: Tue Jun 24, 2008 9:22 am
Here is my setup
If no figure or light curl figure, cutaway or no cutaway: Thin to .085-.09. Light sprits of distiled water. bend at 290
If high culy figured no cutaway: Thin to .08-.085. Light sprits of distiled water. bend at 290
If high curly figured and cutaway: Thin to .08-.085, .075-.08 in the cutaway. Treat with SuperSoftII for three days. Light sprits of distiled water. bend at 290-300
PostPosted: Tue Jun 24, 2008 11:30 am
I can tell that already. Thanks for the lead here.
Chris
Users browsing this forum: Bing [Bot] and 20 guests
