Hi Ricardo;
Seems there are a few bending questions popping up here. I will offer my pennies worth with regards to case hardening, if it helps. (case hardening pertaining to woods anyway.) I don't know what thickness you're trying to bend but I've found a huge difference between .090" and .075" as far as a cutaway area, when I do a sharp cutaway, I bend both sides equally and after setting the sides in the form I mark and cut the side at the spot I start the cut away and then rebend it rather easily, (to keep the same grain pattern) . It could be that you are scorching the wood and this will be evident by black marks and the feeling of brittleness in the piece, if the resins are burnt or the oils in the woods are dried up, you're bending at too high of a temperature, try decreasing the heat and holding pressure in the bend as it "gives" to the iron, walking slowly over the heat in gradual increments as opposed to just setting it on the iron and waiting for it to bend, I will often drape a soaked rag over the iron and move the piece around slowly as it starts to creep and bend, but holding the bent pressure is a key to reducing spring back until it cools. Actually E.I.R. is what I'm basing this off of, as I find it really easy to bend to very tight radiuses at appropriate thicknesses, (say around .080".) If it's not bending for you too easily, I'd suggest thinning it slightly.
_________________ Nehemiah Covey www.coveysacoustics.com
