It is currently Fri Sep 19, 2025 12:04 am
 Post subject: Sharpening Ibex blades?
PostPosted: Sun Dec 07, 2008 10:08 am
State: ON
I was wondering if anyone has tips for sharpening the blades on the Ibex finger planes. My brother and I are building a Mandolin (A-style stewmac kit) together and have started work carving the top. I'm all set up to sharpen flat blades but am not exactly sure what to do with the small convex blades that the Ibex planes use. Any tips would be appreciated.
Josh
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Sun Dec 07, 2008 10:17 am
Josh...I was able to successfully do them by hand by rolling the convex side of the blade over sandpaper on glass. The flat side is simple. It's a bit fussy because of the small size but once honed, I've been able to keep a SS edge with an occasional touch up on the leather strop. I carved out a LP curly maple top with the blade sharpened this way. Good luck!
PostPosted: Sun Dec 07, 2008 3:50 pm
First name: Wayne
Last Name: Clark
City: Driftwood
Josh,
I use the sandpaper method JJ mentions to get the blade sharp to start with. To keep the blade in good shape as I use it, I made a little honing jig for my blades. I glued a scrap piece of leather ~2 X 6 onto a scrap piece of MDF. I rub a little chromium polishing compound on it and then give the blade a few swipes across it to touch up the edge as I go. It will restore a razor edge to a blade in just a minute or two.
PostPosted: Sun Dec 07, 2008 7:00 pm
japanese water stone cones for the curved side .... or the LV 1 inch sander with 1200 and then leather strop belts if you have that ...
PostPosted: Mon Dec 08, 2008 8:50 pm
Carve out a chunk of basswood or (?) the shape of the blade (with the blade), use sandpaper method in the 'tube' to hone. They use this method in various forms to sharpen carving gouges but opposite of course.
PostPosted: Thu Dec 11, 2008 9:04 am
State: ON
Thanks for the tips guys. I will give some of those methods a try and I'm sure they will help a lot.
Josh
Josh House
