It is currently Sun Apr 19, 2026 8:55 pm
 Post subject: Label glue?
PostPosted: Sat Mar 10, 2012 1:04 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I'm about to apply my first label. It's a nice parchment paper which has been shellacked. What is an appropriate adhesive? Spray glue?
 Post subject: Re: Label glue?
PostPosted: Sat Mar 10, 2012 1:27 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I use hot hide glue..........but I use hot hide glue for pretty much everything. I believe pretty much any type of glue would work, including spray adhesive. I use hot hide glue because I always have some handy.
PostPosted: Sat Mar 10, 2012 5:33 pm
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
I like slightly thinned fish glue for this job. Spread it on thin & wipe the label down with a damp paper towel, once it's in place.
Thinned white or yellow glue work fine too.
PostPosted: Sat Mar 10, 2012 6:18 pm
Last Name: Kincheloe
Paper is too mainstream 8-)
:lol: Really, I'd use hide glue for paper labels. http://www.frets.com/FRETSPages/Musician/GenMaint/Label/label.html
Although, the shellac may prevent it from sticking that well, especially if it has to bump over a center seam reinforcement. Spray adhesive may hold better. Run some tests.
PostPosted: Sat Mar 10, 2012 6:27 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I think I will try spray adhesive (3M). See how that works. If it fails, least likely to cause a mess. I have yet to even mess with hot hide glue.
PostPosted: Sat Mar 10, 2012 7:23 pm
First name: David
Last Name: LaPlante
Fish glue is the stuff that's used on reinforced paper box sealing tape. You know that stuff you wet to activate.
It's perfect for gluing paper labels.
PostPosted: Sat Mar 10, 2012 7:26 pm
Last Name: Wood
City: Chester Springs
State: PA
Zip/Postal Code: 19425
I don't shellac my paper labels, don't know how this would work with shellac, but I glue them on with a glue stick from Staples. Has worked great so far.
Chris.
PostPosted: Sat Mar 10, 2012 8:23 pm
Another glue stick convert here.
PostPosted: Sat Mar 10, 2012 8:59 pm
Glue sticks and spray glue get used a lot around here for non guitar related things (paper). In my experience, things stuck with them don't stay together.
Mike Lindstrom
PostPosted: Sat Mar 10, 2012 9:41 pm
I use titebond to hold em down and then paint over them with thinned titebond. I've done that on small signs for over 10 yrs and had labels in instruments for 8 yrs. Still holding up fine with no signs of deterioration.
PostPosted: Sat Mar 10, 2012 10:53 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
The only problem I see with titebond painting is neatness.
No way am I going there.
PostPosted: Sun Mar 11, 2012 12:40 am
Last Name: Shaw
City: Philadelphia
State: PA
Zip/Postal Code: 19125
Now I hope your aware and have verified that your labels are made with the pulp of 300 plus year old spruce trees. :)
Another day, another dollar.
PostPosted: Sun Mar 11, 2012 12:43 am
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
I make my labels from 100% cotton bond, sealed both sides with spray shellac, and glued with slightly thinned Titebond. Any mess cleaned up immediately with damp rag. No fuss, and seem to stay in place.
PostPosted: Sun Mar 11, 2012 1:22 am
City: chicagoland
State: illinois
everyone trips pretty hard about back thickness, stiffness, resonance, etcetera....and applying a label is basically applying an acoustic dampening pad. with this philosophy in mind, i would think about forgoing the paper sheet altogether, and burning/branding or painting/stenciling/inking a logo instead. if i were to use paper, i certainly would not want to use something rubbery to adhere it, such as spray adhesive....rubbery stuff is what studios use to absorb reflection energy and vibration energy. but in the big picture, i bet it doesn't matter
PostPosted: Sun Mar 11, 2012 1:29 am
First name: Marcus
Last Name: Bailie
City: Kirkland
3m Super 77 spray glue.
-Marcus
http://www.bailieguitars.com
Instagram | YouTube
PostPosted: Sun Mar 11, 2012 7:56 am
?? Not an issue unless you're very ham-handed. No different than using HHG or fish glue. Of course I did spend my formative years building models so detail painting is not difficult for me. I'll photograph one later, maybe I wasn't very clear.
PostPosted: Sun Mar 11, 2012 9:07 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
elmers white glue on paper, an a vlnmakers burn in name stamp on the center strip using a lighter
PostPosted: Sun Mar 11, 2012 10:05 am
I switched to doubled sided adhesive sheets from LMI that are intended for pickguards. Very thin and sticky, just trim them to the shape and stick 'em. No issues for 2+ years on the ones still on the bench (yes, I build that slow!).
PostPosted: Sun Mar 11, 2012 8:47 pm
First name: Patrick
Last Name: Hanna
State: Missouri
What Marcus and Todd said. It's true. And if you're worried about your ink jet ink or your laser toner, print several copies and experiment a bit with Krylon artist's workable fixatif #1306, or their Kamar artist's varnish. MIST COATS ONLY!!! AND ONLY TO THE SIDE WITH THE INK / TONER, AND FROM ABOUT 12" AWAY FROM THE LABEL. This is why I said print several copies. Inevitably, someone will shoot a heavy coat of either from about six inches away, and their label will instantly dissolve and run. It doesn't need to be that way. Mist coats from 12" away. Ten minutes of drying time. Between each coat. Two or three coats. Then It works.
Then 3M 77 on the side you want to stick. Again, print a few copies of the label, just in case the first one gets contaminated with the sticky stuff.
Clean your aerosol cans as usual (and immediately), shooting upside down into an empty box or a piece of old newspaper until only the propellant comes out.
One other thing, and this is IMPORTANT!: These fixatif / varnish spray products are as volatile and noxious as nitro-lacquer. Spray outside, or in your garage, or in your well-ventilated spray booth, and wear you respirator mask. I mean it.
PostPosted: Mon Mar 12, 2012 12:24 am
Glue is too messy. I use double sided tape.
PostPosted: Mon Mar 12, 2012 12:27 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
I use 3m spray adhesive. Be sure you don't use pulp paper or it will ruin the guitar's tone lol beehive
PostPosted: Mon Mar 12, 2012 12:54 pm
Last Name: Shannon
City: Milford
State: OH
+1 for 3M Super 77 (with shellacked parchment labels).
PostPosted: Mon Mar 12, 2012 12:57 pm
Fish glue.
PostPosted: Mon Mar 12, 2012 1:10 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Who'd a thunk a question about label glue would attract so many answers and different ideas? :)
Thank you all!
PostPosted: Mon Mar 12, 2012 6:43 pm
First name: Chuck
Last Name: Kish
City: Saratoga Springs
Zip/Postal Code: 12866
Never had a problem using slightly thinned Titebond. I spray with some clear shellac, lacquer, whatever I have around, brush on the glue and clamp it in place until the glue dries. I do it before final assembly. Have some dulcimers over 30 years old without an issue.
Chuck Kish
