It is currently Mon May 11, 2026 8:03 am
Post new topic Reply to topic  [ 1913 posts ]  Go to page Previous  1 ... 73, 74, 75, 76, 77
PostPosted: Fri Mar 20, 2026 3:03 pm
Last Name: Kincheloe
Sticks are too curvy and irregular to turn into a long dowel, but you probably could cut short pieces and do it. Then hold the end with a collet chuck while shaving the taper.
For sanding I just use a regular 5mm collet. It can't actually clamp the taper, but as long as you keep positive pressure on it while sanding it grips just fine, and is super quick to swap to the next pin. But for cutting the head as a separate operation, the taper collet is a good idea. Definitely make it out of wood. Aside from being easier on your reamer, the friction grip will be much better than metal.
PostPosted: Fri Mar 20, 2026 3:42 pm
City: U.P.
I was thinking with sticks, once a segment was round enough to stick in the shaver and turned into a cone it could be lopped off and the next segment run into the sharpener.
So really the stick would only need to be reasonable straight for an inch or so and the sharpening would make the cone straight. You could whittle it round enough to start in the shaver pretty quickly.
Doesn't have to be a dowel per se. The dowel plate was more for folks wanting to cut lumber and form dowels to start with, but could be used with reasonable straight sticks to get close to shaver dia.
The "ice cream" knob on the top of the cone need not be round or regular as long as it is bigger then the finished ball end.
I like the stick idea. Every now and then you find bushes with very hard wood and interesting grain that would never get big enough to mill lumber. Lilac wood is one, there are lots of others, many fruit trees are hard and heavy too. I'm going to start collecting!
Brian R, Wood Mechanic
N8ZED
These users thanked the author rbuddy for the post: DennisK (Fri Mar 20, 2026 5:57 pm)
PostPosted: Wed Apr 01, 2026 9:36 am
Online
Made the very first setup ever on a vintage Guild B-302 bass. Truss rod not so bad, bridge and nut slots were both stupid high. Saddles on A and G strings were reversed (probably from the factory). Now it plays nice and sounds unique - closer to Rickenbacker than a Fender.
https://i.imgur.com/43WT6XX.jpg
These users thanked the author Chris Pile for the post: Kbore (Sun Apr 05, 2026 11:25 pm)
PostPosted: Wed Apr 01, 2026 10:06 am
Always cool to get your hands on vintage gear. I am surprised how poorly setup some of the basses are that I get in the shop. Owners are pretty amazed when they get them back.
These users thanked the author SteveSmith for the post (total 2): Chris Pile (Wed Apr 15, 2026 8:47 am) • Kbore (Sun Apr 05, 2026 11:25 pm)
PostPosted: Wed Apr 01, 2026 1:47 pm
It’s amazing how often actual players are clueless about the functionality of their chosen instrument.
These users thanked the author meddlingfool for the post (total 3): Chris Pile (Wed Apr 15, 2026 8:47 am) • Kbore (Sun Apr 05, 2026 11:25 pm) • SteveSmith (Wed Apr 01, 2026 2:08 pm)
PostPosted: Wed Apr 01, 2026 2:26 pm
Online
In all fairness, this belonged to a student and his instructor asked me to "make it work".
PostPosted: Wed Apr 01, 2026 2:39 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
Just about finished with the French polish on the BRW classical
These users thanked the author johnparchem for the post (total 7): Bryan Bear (Wed Apr 15, 2026 10:16 am) • Chris Pile (Wed Apr 15, 2026 8:46 am) • Michaeldc (Sat Apr 11, 2026 3:40 pm) • Darrel Friesen (Sat Apr 11, 2026 10:10 am) • Kbore (Sun Apr 05, 2026 11:25 pm) • SteveSmith (Thu Apr 02, 2026 5:57 am) • rbuddy (Wed Apr 01, 2026 6:32 pm)
PostPosted: Wed Apr 01, 2026 6:33 pm
City: U.P.
Beautiful John!
N8ZED
PostPosted: Thu Apr 02, 2026 9:12 pm
Last Name: Colbert
City: Anacortes
That’s a gorgeous finish, John!
PostPosted: Sat Apr 11, 2026 9:11 am
First name: Ken
Last Name: Nagy
City: Goodrich
I've been doing oil paintings this year, painting from a National Parks daily calendar. I've done about 2 dozen so far. Getting better. On the last one still of the panel I used some Sandarac varnish I got from an artist who makes varnish. I got it for violins! I did that entire painting in less than 3 hours, and it was dry to the touch. I didn't thin it with turps like he said, because my wife doesn't like the smell. I do. I don't like OMS. Ordorless? I don't think so. That varnish (the smell was very mild, and was gone by the morning with the painting in the garage overnight.) will be my go to.
I want to do some plein-air paintings. Not in the cold though. I made up a pochade box with a 12 X 16 glass palette; and an easel attachment. The box goes on the legs of my tripod, and the easel on the camera attachment.
I'm making a box to carry 8 canvases/paper on 4 panels. I call it a small camera. Something an artist back in the early 1800's could carry on a trip, and bring back memories. Maybe do them bigger. I'd like them to be good on their own. The 3 hour one is 7 X 11. The camera can hold 9 X 2 panels. That works out to 4 hours. I have to get faster than that.
I cut 4 of the 8 grooves to slide the 4 panels into yesterday. 1X 2 from Home Depot; from NEW ZEALAND? Marked it out deep with my marker, and then cut it with a Dremel on a purfling groove attachment. I don't have a fence for it. It worked great. Now I have to do the outside grooves, and get a 2 X 4 smooth sided hardboard panel. HD only hard ones that were corrugated on one side. That won't do.
So I did do some woodworking, on the pochade box, the easel and now the 9 X 12 -8 frame "camera."
Why be normal?
These users thanked the author Ken Nagy for the post (total 2): Chris Pile (Wed Apr 15, 2026 8:48 am) • SteveSmith (Sat Apr 11, 2026 3:57 pm)
PostPosted: Wed Apr 15, 2026 8:34 am
Nice work Ken. Only painting I've ever done that looked any good were the ones with numbers :D
PostPosted: Sun Apr 19, 2026 12:09 pm
First name: Ken
Last Name: Nagy
City: Goodrich
Steve,
It's only a matter of mixing the paint color, and putting it where it goes on the drawing. Somehow I'm good at it. Visual Communications (water color, and still life charcoal) in college was my favorite class in 74.
I watched a video and decided I'd make my outdoor thing just for the 9 X 12 size max. I'll use the big one, and the huge one I got real cheap at a garage sale at home. So I added a tang on the bottom, to attach it to the tripod. I have a piece in the middle that will be an open box, that can hold a cardboard box with paints and stuff; attached to it will be the smaller palette, and not the big one with the swing open cover. The palette will be at about a 45degree with the painting holder that also works as an easel.
The big problem is that smooth double sided hardboard seems to have gone the way of the dinosaur. Why? It was nice stuff. That corrugated side stuff is nasty. I found chalkboard that seemed like a good bet, and I will use it. But I found after cutting it that it is WAY heavier than the 50% thickness difference between that, and 1/8 hardboard. 4 panels is 3 pounds? Why?
Well, I weighed the large smooth hardboard panel I use for 12 X 16’s; it’s almost exactly twice the area of the 10 X 13 chalkboard panels, and it weighs 1.5 pounds. Apparently the hardboard is actually denser.
Why be normal?
These users thanked the author Ken Nagy for the post: SteveSmith (Sun Apr 19, 2026 7:01 pm)
PostPosted: Wed Apr 29, 2026 8:09 am
First name: Ken
Last Name: Nagy
City: Goodrich
The pochade box is pretty much done. I need to put t screws with flat heads on the center piece to hold the blue plastic boxes to hold the glue bottles with oil, and solvent. It could use some sort of finish maybe. It folds up with a box that holds paints, the glue bottles, and palette knives. A rollup brush holder carries the brushes, and should fit in against the outside of it, with the paper towel.
It is pretty stable on the tripod. The center of the painting will be at eye level, and the palette is right in line at about 45 degrees, so you see it flat. I might figure out some straps to carry it on my back. The tripod, a garage sale find, has a bag with a handle. I'll drill holes in both pallet covers to hold brushes; clean on the right, and used on the left. If I have brushes with every color on the left, I can just grab them, unless I need something smaller.
My other palette I made is twice the size. I will just find, or make a table to set it on, and use it in the basement with the huge one I got for $5 or $10 at a garage sale during the M15 garage sale they have every year the first weekend in May, that started this painting thing.
Why be normal?
These users thanked the author Ken Nagy for the post (total 3): Darrel Friesen (Tue May 05, 2026 9:53 am) • Chris Pile (Wed Apr 29, 2026 11:50 am) • SteveSmith (Wed Apr 29, 2026 8:48 am)
Users browsing this forum: No registered users and 44 guests
