It is currently Sat Sep 20, 2025 11:57 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
 Post subject: Re: Your Truss Rod
PostPosted: Wed Sep 17, 2008 8:57 am
What Mark said,
filler strip or spline on top, use a hardwood (only need like 1/8" max), no silicone here either.
I use a 1/4" flat bottom spiral bit to cut the channel.
PostPosted: Fri Sep 19, 2008 9:42 am
Ok so I just ordered 12 of these from Allied. I was only going to order 6 but @$12 a piece when you get dozen or more. I guess I have to build atleast 12 guitars. bliss
David
PostPosted: Sat Sep 20, 2008 12:37 am
I read Allied's instructions for gluing the filler strip, and it sounds like the strip will end up being thicker in the middle when it's all leveled. And the rod would initially be bowed up inside the channel due to the clamping pressure in the middle. Am I understanding this right?
Jeremy
PostPosted: Sat Sep 20, 2008 6:33 am
Jeremy
That is correct.
Mark
Users browsing this forum: jfrench and 34 guests
