It is currently Wed Aug 13, 2025 3:48 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Thu Jan 14, 2010 1:43 pm
kmason wrote:
Hesh, in the photo you attached to your reply, what is the white box sitting on top of your Festool?
Kevin the white boxes stacked on the Festool vac are called (by Festool) systainers and they are the boxes that come with Festool tools. They are designed to be solutions for tool storage and access and really quite clever. They stack as you can see and since the vac has an excellent set of wheels this means that the tools in your stack are moved when the vac is wheeled around.
In my case I have from top to bottom the drill which is superb, the 5" ROS which is also the nicest that I have used for how I use a ROS, and lastly a cleaning kit.... :D that came with a 3 piece wand, attachments, and the hose you see pictured which is larger than the hose used to hook directly to the tools. BTW the real beauty of all of this is that it's a system and the vac hose plugs directly into Festool's ROS's, routers, jigsaws, and more so that dust and chips are removed at the source.
Users browsing this forum: johnparchem and 33 guests
