It is currently Sat Aug 09, 2025 1:26 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
 Post subject: Re: Number 100 Complete
PostPosted: Mon Sep 26, 2011 8:08 am
Congratulations on your 100th David.
A great accomplishment and a beautiful guitar !
PostPosted: Mon Sep 26, 2011 10:02 am
First name: David
Last Name: LaPlante
Thank you, all,
In terms of the 1 11/16" inch nut width, this was specified by my client (who incidentally had no idea that the next guitar in line would be #100) who had been playing an electric nylon with that width. Considering he's a jazz player and due to hand issues he feels that it's just right for him. The other instrument also had a 24 3/4" scale which is short for an acoustic nylon string and I made some changes in the construction to compensate for the lower tension. These included a slight shift forward of my standard fan bracing pattern as well as slightly lighter (by about 1/2mm) dimensions on the fans themselves.
Along with the longer 14 fret neck nylon that I sometimes make I also used a two way truss rod (with a through the soundhole access) on this one to enable precise adjustment of the neck relief.
After 100 instruments I'm not sure how I might have proceeded differently considering the amount of time it took (45 years) and that so many of them were made at the request of others and that all of it (as everything does) took place within the context and constraints of daily life.
I will say though that I tried to work incrementally and avoid big swings in construction method or style which I think allowed a systematic evaluation of what changes produced what results and allowed me to build my knowlege base (albeit slowly) in a linear fashion.
I'll be starting #101 soon, see you in another 45...................
Best!
PostPosted: Mon Sep 26, 2011 2:41 pm
First name: Gary
Last Name: Lee
David,
Congratulations on your truly inspiring milestone! Best wishes for No. 101 and beyond.
PostPosted: Tue Sep 27, 2011 10:11 am
First name: David
Last Name: LaPlante
Thanks Gary,
To you as well, hope to see you at some point in the future!
