Ken Jones wrote:
WaddyThomson wrote:
Another useful tip is those magnetic calendars folks give away. Cut them up into squares and stick em on the scraper. Push your thumbs against that - protects against the heat.
Great tip. I have actually scalded my thumbs from leaning into a scraper whilst leveling bindings. Yeouch!
Ken
I had to do a lot of the thinning on some Honduran rosewoods sides by scraper, due to some knot shadows causing the grain to tear if I used a plane. I wear gloves for the heat, but still had to stop regularly for fear of creating embers in the pile of fluffy shavings
There's also the Veritas scraper holder, but I haven't had good luck with it. Get much better shavings holding the scraper directly.
As for sharpening, I currently use a file on the edge and then burnish from the faces, then the edge, and then angle the hook back maybe 10-15 degrees. But that does leave the faces to get a little rough after a while, which I hope to solve using the DMT extra-extra-fine diamond stone I bought recently.
Perhaps I can use diamond stones in place of the file for refreshing the edge too. As it is, my hook isn't quite as smooth as I'd like it to be. The scraper that came with the Veritas holder worked better when I first got it, and gradually degraded to the level of my other one with each resharpening.
Also, I always round over the corners, because the two on the cutting edge can scratch the wood, and the other two poke my hands. I've never run into a situation where I wished I had sharp corners on a card scraper. Whenever I need sharp corners, I also need a chisel style beveled blade that can get into tight spaces better than a 90 degree edge.
