It is currently Tue Aug 19, 2025 11:34 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Tue Oct 16, 2012 10:19 am
meddlingfool wrote:
Share your schedule Alain?
Sure!
- Two coats of schellac (Zinsser Seal coat, like I mentioned). I now do this in all cases, not specifically on rosewood. I sometimes had some uneven colors when I was directly applying polyurethane on wood. Specially on cedar. Shellac resoved this.
- I then proceed with applying about 5 to 7 coats for the build-up using a foam brush, where I scuff with 400 grit between coats. I can give two coats a day, waiting about 7 to 8 hours between coats.
- Once the wood texture has disappeared everywhere on the guitar, I then wet sand with 320 quite heavily, taking special attention on runouts and drips (which I was never able to avoid during build-up). I will almost always sand through the finish on several places. I wipe on some shellac on those areas with a paper towel afterwards.
- I then apply what I call 'finishing coats'. I clip some paper towel folded in two over a foam brush, and proceed with applying my polyurethane with that. This little setup makes sure the coat is really thin and thus greatly minimizes runouts. I apply 5 coats, where I sand between coats. 1000 grit after the first and second coats (just light scuffing), 1500 after the 3d and fourth (appying myself a little more), and then finish with 2000 prior to buffing.
- I buff using a Stewmac buffing arbor, using medium and fine menzerna compound.
- Buffing touch-ups with colortone fine buffing compound and a soft rag.
I think that's pretty much it!
Alain Moisan
(Now building just for fun!)
Users browsing this forum: DennisK and 21 guests
