It is currently Sat Aug 09, 2025 11:27 pm
Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2
PostPosted: Thu May 14, 2015 6:59 am
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
Holy smokes, don't you guys know when you're being played? Drew you in hook, line and sinker!
(You were playing 'em, right Bill?)
PostPosted: Thu May 14, 2015 7:26 am
Generic dental floss works great. bliss
PostPosted: Thu May 14, 2015 7:39 am
Hesh wrote:
Yeah it's a nice break for me Michael from having to point out that you are flat out wrong with the following assertions that you have made in the past as well..... laughing6-hehe laughing6-hehe laughing6-hehe
Assertion 1: Finger pressure is all that is required to glue on a bridge. You made this claim without further explaining that this is a practice that some classical builders do and do successfully but you neglected to realize that for steel string builders this would be a nightmare, would not work, and could damage the top when the bridge comes off and it most surely will. Remember that one, Michael?
Assertion 2: Or the time that you claimed that you can do precision fret work with a PLEK as a discussion standard with only a file for the leveling process..... :roll: Even after you insisted that you were correct when I insisted otherwise and challenged you to a contest of sorts having your work scanned on your side of the pond by a PLEK of your choice and I would do the same, winner pays for both scans... you wussied out.... More bad advise from you....
Assertion 3: When Dave Collins shares his saddle mill with you you assert that you can do all that a proper saddle mill can do with a plow plane, a plow plane mind you.... When it's pointed out to you that not all saddle slots are through saddles and that with a plow plane you have to do the additional step of filling the ends, which does not have to be done with a saddle mill, instead of admitting that you are incorrect you continue to insist that you are correct.... Even more bad advice from you.....
Assertion 4: You insist that you can cut nut slots as cleanly, as quickly and as precisely with a needle file as one can with proper, modern nut slot files.... that is when the tip is not breaking off your little needle file....
You claim to be a professional yet you remain very closed to methods that are not what you do AND it's not bad enough that you remain closed you promote methods that are unsound, don't work with little regard for the idea that one day someone is going to take your very poor advice and something is going to go south for them. You don't seem to care.
Remember the pearl glue thing where you claimed it the same as HHG? It's not, far from it.... Grammatical errors you say.... how about what comes from you flat out incorrect information that clearly indicates that you have no clue what you are doing....
Ax to grind Michael? Bad advice catching up with ya is it? laughing6-hehe
I've provided you with my email in the recent past in MY effort to take the unpleasantries out of view and off the radar for other OLFers so as to not pee in the collective canteen here. Yet you refuse to have constructive dialogue with me that just might.... just might.... have possibilities that you might benefit from and of course everyone else here might also appreciate a cessation of hostilities....
Sheesh!!
Again Michael if you would like to attack me, again... use my email and I would very much welcome the opportunity to be completely honest with you as well..................................
You are a complete joke Hesh, and quite a nasty one at that. The bullyboy of the forum!! :? Others may let you get away with it. I won't. I'll call you everytime.
Allow me to point out a few home truths (just as Simon did!! [clap] ):
I don't have a problem cutting Nut slots with a needle file. I've been doing this since 1977. You may have trouble with it but perhaps that's because you lack the required skill. I think you started in 2007? Some of us have considerably more experience than yourself. The fact that we do things differently is neither here nor there. I have never (as in not once) had one single complaint from one single Player regarding the Nut slots. I guess I must be doing something right. For some rather strange reason you simply cannot accept that the method works if you have the required skill, not that it takes much skill in the first place though!
As for the saddle mill. All I pointed out was that I could (and indeed did) execute it with a plough plane and scratch stock. What's the big deal with having to insert end pieces? Done well it's invisible for practical purposes. You do know that you insert wood pieces into the bridge yourself? :o :roll:
Besides, what makes you think that you are the arbiter of good practice? i don't think you have been at this long enough to start becoming a world authority on what can or cannot be done.
Rubbed Joints: This is rather interesting. I asked you during that particular thread if you had ever tried it. You didn't answer. I can only assume that you have not. I think you stated that the Guitar factories did not carry out the practice. Perhaps you worship at the alter of the factories but I don't.
But wait. I gave you a real life example of an instrument (the Baroque Lute) that has steel string tension and that is often glued with a rubbed joint. I've done it myself, a number of times. Why do you fail to acknowledge that? I think I know the answer. You have absolutely zero experience of that particular instrument and therefore dismissed it. In fact you made a rather poor comment about early plucked instruments. A rather scandalous comment given the history of the making of stringed musical instruments. It showed a distinct lack of respect for the craft. Hardly befitting of a professional luthier.
Frets. Again, Hesh way or no way. You've actually no idea how I do my frets and fretboard. You made a very false assumption (you do that a lot) that the fret rocker was my only method of checking the frets. Wrong, yet again Hesh!! It's become such an addiction for you. These attacks on other people's methods. Methods that have worked for me (and others) for decades.
Finally. Why is it always yourself that is involved in these altercations? I mean it's quite possible that it's your adversarial style and your distinct lack of appreciation of how others do things differently. Perhaps that is the root cause. Seriously, picking someone out because they used the word 'Kerfing'!. It's language! That's how it works, it changes, it evolves. That's how new words are formed. Besides, I have much more difficulty understanding your rather lengthy verbose posts than the simple word 'kerfing'. If words matter Hesh how come your posts are ridden with serious grammatical errors, such that it's often difficult to ascertain their true meaning?
These users thanked the author Michael.N. for the post (total 3): Markus Schmid (Tue May 19, 2015 6:37 am) • Alf (Mon May 18, 2015 8:47 am) • Anthony Z (Fri May 15, 2015 8:37 pm)
PostPosted: Thu May 14, 2015 11:37 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Bryan Bear PMoMC
These users thanked the author Bryan Bear for the post (total 2): Alex Kleon (Fri May 15, 2015 5:34 pm) • Hesh (Thu May 14, 2015 1:24 pm)
PostPosted: Fri May 15, 2015 3:04 pm
First name: Rusty
PostPosted: Fri May 15, 2015 5:33 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
This is how we do it, north of the border.
Do NOT mess with us! ;)
Alex
These users thanked the author Alex Kleon for the post (total 2): CraigG (Sat May 16, 2015 7:44 am) • Bryan Bear (Fri May 15, 2015 8:25 pm)
PostPosted: Fri May 15, 2015 8:28 pm
Last Name: Denvir
City: Baltimore
State: ON
Zip/Postal Code: K0K 1C0
To join in with my friend Alex, and as another conflict-averse Canuck :-), I'd like to remind everyone here that the point is not to "win", but to share information.
Thank you both for doing so, and can we stop now?
These users thanked the author JSDenvir for the post (total 3): Colin North (Sat May 16, 2015 12:00 am) • Bryan Bear (Fri May 15, 2015 11:01 pm) • Alex Kleon (Fri May 15, 2015 9:45 pm)
PostPosted: Sat May 16, 2015 7:13 am
What's the refrain of the song that starts with " The snow glows white on the mountain tonight..."
And to get back O.T. and add to the superfluous solutions let's not forget Bondo! Fill them thar kerflings with "tone Bondo snot" and get all the perceived advantages of solid linings with half the work! laughing6-hehe
These users thanked the author Clay S. for the post (total 2): Alex Kleon (Mon May 18, 2015 6:46 pm) • Bryan Bear (Sat May 16, 2015 11:21 am)
PostPosted: Sat May 16, 2015 11:56 am
First name: Patch
Last Name: Rubin
both stew mac and lmi refer to the linings in their pull down menus as kerfing. take it up with those guys and not on here.
there is always someone on here that has to be right and has an unpleasant way of showing us how right they are. this is precisely why i lost interest here. i thought things might improve when todd and padma left but i guess there is always going to be someone who takes that place.
http://www.wideskyguitars.com
https://www.instagram.com/wide_sky_guitars/
These users thanked the author patch for the post: Bill Higgs (Mon May 18, 2015 3:36 pm)
PostPosted: Mon May 18, 2015 4:23 pm
First name: Rusty
And Clay, I found out that if you don't want the Bondo to stick to certain parts, a little ear wax makes a great release agent.
PostPosted: Mon May 18, 2015 4:37 pm
Anyone who's short of the above releasing agent can PM me.
PostPosted: Tue May 19, 2015 9:46 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Just remember, if you use that release agent, your guitar will no longer be vegan. . .
Bryan Bear PMoMC
PostPosted: Tue May 19, 2015 11:08 am
Is there a reason why not put the back on first ? Then its easy to wipe of excess of the only bit visible .. idunno
PostPosted: Tue May 19, 2015 11:14 am
That's the way I do it.
These users thanked the author SteveSmith for the post: Cablepuller (Tue May 19, 2015 11:17 am)
PostPosted: Tue May 19, 2015 11:32 am
Yes -- in my view, the sound board cannot be properly tapped and voiced until it is secured to the rim. If the back is on first you loose this wide open opportunity. Plus if carefully planned you can apply glue and clamp in such away that there is little chance of making a mess. $.02
http://kennethmichaelguitars.com/gluing ... rsion.html
Ken Cierp
These users thanked the author kencierp for the post: Cablepuller (Tue May 19, 2015 12:02 pm)
PostPosted: Tue May 19, 2015 11:38 am
Different strokes, I suppose. I do final voicing with the box closed. Unlike Ken, however, I am not a pro.
PostPosted: Tue May 19, 2015 12:28 pm
First name: Big
Last Name: Jim
Well , By Cracky !!! I cut my saddle slots with a Weed eater and file my nut slots with a chainsaw! I DARE anyone to call me on this ! pfft pfft pfft pfft
"banjos playing in background"
Bwaaaaaahahahahahahahahahahahahaha
laughing6-hehe laughing6-hehe laughing6-hehe laughing6-hehe
PostPosted: Tue May 19, 2015 1:46 pm
First name: Rusty
That's nothing, I can build an entire guitar with just a sharpened US Army mess kit spoon.
PostPosted: Tue May 19, 2015 4:19 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
That's nothing, I can build an entire guitar OUT OF a US Army mess kit spoon!
Bryan Bear PMoMC
PostPosted: Tue May 19, 2015 5:07 pm
Is that with a chainsaw?
Or are you a wimp and use a Swiss Arm knife?
These users thanked the author Colin North for the post: Bryan Bear (Tue May 19, 2015 9:04 pm)
PostPosted: Tue May 19, 2015 7:30 pm
First name: Rusty
Ok Bryan, you got me.
PostPosted: Tue May 19, 2015 9:07 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I do it all with my bare hands. The hardest part is pulling the metal out into the strings.
Bryan Bear PMoMC
PostPosted: Tue May 19, 2015 10:43 pm
First name: Big
Last Name: Jim
Broke more teeth than I care to remember knawing nut slots for the strings !
These users thanked the author WudWerkr for the post: Bryan Bear (Tue May 19, 2015 11:26 pm)
