It is currently Sat Aug 16, 2025 9:36 am
Post new topic Reply to topic  [ 64 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sun Jan 10, 2010 2:25 pm
First name: Wes
Last Name: Young
City: NEWFIELD
Zip/Postal Code: 14867
gozierdt wrote:
On my last finished guitar (I may still make some mistakes worse than this on the two current builds...), I cut the binding rabbets after I cut the mortise for the neck- so- the bearing on the bit dropped into the rabbet- big divot right at the top of the back. I eventually fixed it by applying a small pearl inlay. Actually, it came out looking so nice that I may use it on other guitars idunno
I did the same thing on my first guitar it was a three piece back because I built the back sides and neck from a really old pallet.
So it was in between the back stripes I made the hole symmetrical and spliced in a piece of the drop from cutting out the back.
No one has noticed it yet! its hard to see.
On my most recant build I routed right across the end graft where I was going to miter the side perfling.
then I set the back stripe shallow and sanded thru it :evil: gaah
PostPosted: Sun Jan 10, 2010 2:36 pm
First name: george
Last Name: wilson
City: barhamsville
State: virginia
Zip/Postal Code: 23011
Country: united states of america
Years ago,I saw a guitar top that a builder in Hampton,Va.,who I never met,that had the soundhole bored out on the end with the LARGE bout!
PostPosted: Sun Jan 10, 2010 3:14 pm
I neglected to tighten the chuck on my binding router sufficiently. The cut started out at the right depth, but as it went around it was getting harder and harder to work it, because the bit was slowly coming out of the chuck and cutting lower and lower. By the time I got around to the start position I had routed a binding channel that started out at .9x .250- and ended up .9x .560! ...well, it made for an interesting gift to a friend who couldn't have afforded one of my guitars...
PostPosted: Sun Jan 10, 2010 7:03 pm
First name: Peter
Country: England
I was just finishing cutting out the recess for my rosette. I needed to take off a little bit more so set up my Dremel & circle cutter for one last pass. Started up the Dremel started to cut and to my horror I realised I didn't fully tighten the circle cutter and it slid about 2-3" cutting into the soundboard zig-zagging in a awful mess.
Well, as you can tell, I proceeded to calmly un-clamp the top, pick it up and smash it into a million pieces 8-) .
PostPosted: Mon Jan 11, 2010 10:56 am
Aww! You should have done a "Lazy River" inlay! Sorry for your loss!
PostPosted: Mon Jan 11, 2010 2:19 pm
Putting an electric hand drill down on my workshop floor with a 12" long 8mm flat bit still in the chuck. As I did it, I thought 'that can only stay there for a second whilst I finish this process, or I *am* going to hurt myself.'
About 3 minutes later I walked past it, and snagged the sharp end of the flat bit in my jeans, poking a nice shallow wound in my leg, which then caused me to stumble and trip, driving the end of the drill into my shin a second time, this one nice and deep - It bled an awful lot for a relatively small hole!
PostPosted: Mon Jan 11, 2010 2:38 pm
Cool! Did you get a video of that. Post it on YouTube! :D
PostPosted: Mon Jan 11, 2010 3:04 pm
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
Oh NO Hesh!!! I miss my "Young Apprentice" enormously. He was the only guy who could always tell me where I was when I last abandoned my glasses! I never blamed him for ANYTHING. Except perhaps always dashing round with a broom, cleaning up my beautiful shavings.
How is anyone to know how busy you've been when the floor & the benches are dust free?
Good thread!
PostPosted: Mon Jan 11, 2010 5:48 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
I`ve really enjoyed this post.All I have to add is that I`ve made a whole bunch of these mistakes that have already been mentioned.So why go there?
eek James
James W Bolan
Nashville Tennessee
PostPosted: Mon Jan 11, 2010 6:15 pm
Well I am feeling just a tad brighter now hanging out with you guys..... :D
Daniel your apprentice sounds like it may be a relative of mine..... :lol:
So what's the deal - the rest of the folks here on the OLF never made a stinkin mistake????? :D
PostPosted: Mon Jan 11, 2010 6:53 pm
OK Hesh, I'll 'fess up. I had completed a beautiful French polish on a guitar and was getting ready to glue on the bridge. I carefully outlined the bridge and started to work on scraping off the finish under the bridge to bare wood. Something kept bothering me, but I just couldn't quite put my finger on it. I got the scraping done and slathered some glue on the bridge and about to put it in place when it dawned on me...I had the bridge facing the wrong direction, with the saddle facing the end block. Luckily I had caught it before gluing the bridge down, so wasn't that big of an issue to repair, but frustrating nonetheless.
PostPosted: Sun Jan 17, 2010 12:36 am
First name: Blain
City: Leander
I'm only on #3 so I've still got plenty of time to make more mistakes, but so far the biggest that I've made was probably not checking to see if the cap screw on my router bit for routing binding channels was tight. While cutting the binding channel, the screw came loose and the bearing fell off and let the bit cut deeper than it should have. Luckily I caught the mistake almost as soon as it happened, so simply adding purfling and a little splice of EIR made it virtually invisible.
Blain
http://www.ullrichguitar.com
PostPosted: Sun Jan 17, 2010 11:13 am
Guitar number 4 ... measured for the bridge position at least ten times, then still managed to place it short 10mm ... was all ready to glue beofre I noticed it kinda looked funny, like the soundhole to bridge was too short ... hmm .. better measure that again ....
So anyway, I was lucky and got all the score mark sanded out, except for one spot on the treble side, and that ended up being covered by a tortoise pickguard .. the only one I have ever used !!!
So now I measure 11 times ...
PostPosted: Sun Jan 17, 2010 11:43 am
First name: Hugh
City: Lake Oswego
State: oregon
Built a 14 fret neck for a 12 fret guitar. Had it almost on before I noticed.
