It is currently Thu May 14, 2026 11:52 am
Post new topic Reply to topic  [ 71 posts ]  Go to page Previous  1, 2, 3
PostPosted: Mon Jun 04, 2012 7:40 pm
comfyfoot wrote:
I have been looking forward to your results. I had the same issue, turns out there was an adjustment for that on my machine, never noticed it before. I am also expecting some new belts, I am thinking that heavier paper will help my machine a bit. I suspect that the thinner too loose belt on there now wraps a bit when I push on the belt. With the set up you made, if you had a long enough router table, you could probably get started on that and then move to a finer grit on the belt.
Very cool adaptation Chris, simple and effective,
Rob
I read some where that someone uses a simular design on a jointer for tele or strat necks. He levels the tables and then turns it about a degree and runs several passes. One probably could make a jig to guide a hand plane too.
PostPosted: Mon Jun 04, 2012 8:41 pm
Last Name: Renick
City: Mount Shasta
State: ca
Zip/Postal Code: 96067
Country: us
Jointer sounds like chip city, I can see how easy it would be with the carriage you made. Of course that could justify a spiral head that I have always wanted for the jointer, I just ordered new belts too, so I guess I will be ok for a while.
It would be cool to do that Brunner Shaper jig 360 degrees.
Rob
http://shastaguitar.com/
http://www.kalimbakit.com/
PostPosted: Wed Jun 13, 2012 8:46 am
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
Bump....... just wondering how this was coming along??????
MK5acoustics.com
PostPosted: Wed Jun 13, 2012 5:26 pm
Working on the sander setup. Almost ready to check it out.
I welded up a frame of 1" X 1" X 1/8" angle. Added a 19" X 8" X.230 ground steel plate to the sander bed and plates to each end of the frame. Working on the fretboard carriage and radius guides. Also need to add a vacuum hookup.
PostPosted: Wed Jun 13, 2012 6:09 pm
First name: Trevor
Last Name: Gore
City: Sydney
Sheesh!
This is starting to make my rig look simple. And inexpensive!
http://www.goreguitars.com.au
PostPosted: Wed Jun 13, 2012 7:20 pm
Only $7 for the angle (3' left over) and $50 for the plates grinding included.The other stuff is leftovers and recycled from other projects. Probably going to have about $100 into it if I make it a vacuum clamp/ hold down. I think it's a pretty simple design. Still a lot cheaper then buying a $800 edge sander right now. That is if it works . :P
I kind of like the challenge of seeing if I can make it work too. Plus, it's a lot tighter and more precise set up then the prototype. And I like the color too. :)
I'm also thinking about how nice it will be to inlay a fretboard and just take it back to the sander to level it. Something one can't do with a router hookup. Just a thought.
PostPosted: Wed Jun 13, 2012 7:54 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
what brand of belt sander is that????
MK5acoustics.com
PostPosted: Wed Jun 13, 2012 8:08 pm
Reliant, they don't make it anymore but it's pretty much the same as the one HF sells, just a different color. It's about 11 years old now.
PostPosted: Wed Jun 13, 2012 8:47 pm
Last Name: Renick
City: Mount Shasta
State: ca
Country: us
Looks great Chris. I like the adjust-ability of the plates. I agree, this is super simple. It will work well, no advanced math involved.
Rob
PostPosted: Wed Jun 13, 2012 10:15 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
thought it looked a little familar....I am interested in a 6 inch sander and of all the ones I have looked at...craftsman, delta , etc...the HF sander looks to be the sturdiest one of the group....i.e. less plastic??!!
MK5acoustics.com
PostPosted: Sun Jun 17, 2012 5:51 pm
Ok, it's done and tested and it is working. Here's the finish pics.
I decided to go all the way and make it with a vacuum chuck for the fretboard attachment. I use a compressor from an old $20 fridge I bought, very quiet. I also use an on/off foot switch from HF with a T splitter to start the sander and shopvac at the same time freeing up my hands to hold the carriage.
Last edited by Chris Paulick on Sun Jun 17, 2012 6:58 pm, edited 4 times in total.
PostPosted: Sun Jun 17, 2012 5:58 pm
With the 19" bed plate sistered to the bed I don't have to move the carriage to and fro like on the Somogyi jig, I just added a front stop and just move, roll and swing the carriage like on the Fox jig.
Last edited by Chris Paulick on Sun Jun 17, 2012 10:08 pm, edited 4 times in total.
PostPosted: Sun Jun 17, 2012 6:01 pm
more
PostPosted: Sun Jun 17, 2012 6:05 pm
more
PostPosted: Sun Jun 17, 2012 6:08 pm
That's it
PostPosted: Sun Jun 17, 2012 6:37 pm
Looks good Chris; both the tool and fretboard.
PostPosted: Sun Jun 17, 2012 7:43 pm
AMAZING! Great innovating!!! [clap]
That is some first rate machine you built yourself there!!
Id really like to build a compound radius jig - but in my puny shop I really have to make efficient use of space... which of the two types sanding vs routing is more compact? yet still effective...or is there not much difference...??
I can see huge advantages in the sanding type but I dont have a large sander momentarily...
I dont mind buying plans for one either.. I just want something that works - but one I can tuck/roll away too.
I prolly wont need one that will do super extreme compound radii either, just standard-ish ones...
Any suggestions?
Charliewood
PostPosted: Mon Jun 18, 2012 7:18 am
That's pretty cool Chris. Very "simple" solution.
PostPosted: Mon Jun 18, 2012 7:47 am
State: Tennessee
Very nice, going to be working on one of these.
PostPosted: Sun Jun 24, 2012 5:25 pm
I ended finding one (free plan) to suit my needs - simple and compact enough to stick away - thanks for all the help though ;)
cw
PostPosted: Sun Jun 24, 2012 6:12 pm
http://www.youtube.com/watch?v=qgfEM71sja0
Users browsing this forum: No registered users and 72 guests
