It is currently Sun Aug 17, 2025 5:58 am
Post new topic Reply to topic  [ 66 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Jan 30, 2013 4:20 pm
First name: Rienk
Last Name: Ayers
City: Santa Maria
ZekeM wrote:
Whatever shop you contacted was just quoting you a crazy number to scare you off cuz they don't want the work.
That's what I figured... but I'm in California, where most people deserve to get paid not to work, and those who do work deserve to get paid triple (so they can have some left over after they pay for those who aren't working).
HELP! [uncle]
PostPosted: Wed Jan 30, 2013 6:24 pm
Having escaped from California and moved to Tennessee about 14 years ago I can verify that there are some major price differences.
PostPosted: Wed Jan 30, 2013 9:49 pm
First name: Rienk
Last Name: Ayers
City: Santa Maria
Filippo Morelli wrote:
grumpy wrote:
I'd place the bearings as near the buffs as I could get away with, and with the large diameter buffs, they could be just about -at- the buffs.
Absolutely. I've seen a lot of supports for buffers that leave me unimpressed. Once can build a svelte structure that does not get in the way of buffing but extends out to support pillow blocks close to the buffs - it's not that hard, really, but I don't see many folks doing it...
That's a good point; if the blocks are right next to the wheels, it would be virtually impossible to hit them (the angle would be too steep). I guess it's just that most systems have a central casing that you want to keep a guitar body away from, thus the desire to cantilever the wheel as far out as possible. Nonetheless, there has to be some sort of pulley on the shaft, and it either needs to be in the middle (equadistant from from both buffers) or also right next to one of the buffing wheels. The shaft will always be in the way to some degree, but if you can keep everything else away as well, that is ideal.
Thus, if you built some sort of metal frame that the pillow blocks bolt to, right next to the wheels, and the frame is behind the shaft and almost no wider than the pillow blocks, then everything should be close to ideal. Other than the pulley, you wouldn't even need the shaft to be that long - just want to make sure the body won't ever touch both wheels at the same time (or in the same movement).
That definitely gives me some more to think about in the design.... but since I'll probably keep the pulley in the middle (to balance torque) I'll still probably go with a longer shaft; I have a 48" which seems about right with the 7" pulley I have.
I'd like to hear what other people's layouts are going to be.
PostPosted: Wed Jan 30, 2013 9:50 pm
First name: William
Last Name: Snyder
City: Brooklyn
Just a quick update: Today I received my 1" x 39 3/8" axle that I paid $14.95 for. From initial inspection I'm very pleased. The machining is nice and crisp. Threads were well protected for shipping. I can't tell yet with any degree of precision but, sighting down it, it seems very straight and it rolls just as straight and true as you could want it on a flat surface.
The only flaw I could find with it is that it isn't coated in any sort of protectant so it does have one spot of light surface rust about the size of a dime. I think I'll live.
I'll be a bit surprised if this doesn't do the job quite well. Again: $14.95. I don't know how or why but so far looks good.
PostPosted: Wed Jan 30, 2013 10:07 pm
First name: Rienk
Last Name: Ayers
City: Santa Maria
Bingo. No reason this can not be done with plywood, either. Stiff and will soak vibration (compared to steel, imho).
For me, it's because I am planning on mounting the pillow blocks vertically instead of horizontally... I want the shaft to be the furthest most part of the system sticking out from the wall, not the frame. And for that, I trust metal more (probably not the best reason, but then I also have a full metal shop that can make it for me, so it's almost as easy).
However, with the pillow blocks up against the wheels, that 1" shaft is starting to look very appealing - as a step-up bushing is easy enough to slide on for the 1-1/4" buffing wheels (and pulleys are much more common - and less expensive).
PostPosted: Tue Feb 05, 2013 1:13 am
First name: Rienk
Last Name: Ayers
City: Santa Maria
Todd Stock wrote:
Hence, the 1-1/4 shaft versus the 3/4 on my current older SM. No prob buffing new stuff, but repairs or neck through stuff wants more clearance than available. Larger wheels help as well...18" is 3" more to the shafts than the old SM.
Where is a good place to get 16-20" wheels?
PostPosted: Thu Feb 14, 2013 1:20 pm
First name: Rienk
Last Name: Ayers
City: Santa Maria
Any further discoveries on getting larger shafts machined?
PostPosted: Sat Feb 16, 2013 2:19 pm
I couldn't pass up the 1" x 39" axle for $14.99, total $20 and change to my front door. My current buffer has a 3/4" shaft and a short axle, so I was looking for a little more room for buffing. The 1" go cart axle turns out to have about .015" run out, so I may have to redesign and move the bearings closer to the ends. Also, I am not sure how well the lock nuts will hold since both sides are right hand thread. For now, I am going to give it a try as soon as I get larger diameter buffing wheels. Here's a couple of pics of my simple buffer minus the motor and on/off switch...with welding required;
Chuck
PostPosted: Sat Feb 16, 2013 2:41 pm
First name: Rienk
Last Name: Ayers
City: Santa Maria
I talked to that axle shop on Thursday, and they said that they would machine a solid 1.25" aluminum axle with L&R threads for about $55-60 each (I told them we might do multiple).
However, though AL is stronger than steel, it is three times more flexible, so even with the larger diameter, the bearings may need to be much further outside. On the other hand, my structural engineer (who races motorcycles and designs some race car stuf) thought that racing cart axles 2would probably use alloys that have similar stfifness, and thus may be okay? Unfortunately, they don't stock 1.25" solid steel, and the owner won't bring it in for a small order. But they may be willing to thread their hollow steel axles... they have 1/4" wall thickness, which should leave plenty of material under the threads for some buffing wheels to hang of of. I hope to find out on Monday.
PostPosted: Sat Feb 16, 2013 2:46 pm
First name: Rienk
Last Name: Ayers
City: Santa Maria
BTW, I am having a batch of 18" 16ply (1.25") buffing wheels made.; medium, fine and extra fine. If anyone wants to tag onto the order, I can have them shipped to you (minimum of 4).
I will get pricing next week (should be less than $25 each).
PostPosted: Tue Feb 19, 2013 9:11 am
Aluminum is not stronger than steel unless you are factoring the strength per weight basis. But in an application like this, weight is not really a consideration.
PostPosted: Tue Feb 19, 2013 8:51 pm
First name: David
Last Name: Eddy
City: Mandeville
State: La
Zip/Postal Code: 70448
How many of you guys use ventilation fans behind the buffing machine?
PostPosted: Tue Feb 26, 2013 1:16 am
First name: Rienk
Last Name: Ayers
City: Santa Maria
Well guys, for lack of further input from others, I've pretty much decided to go with a 1.25" aluminum shaft, threaded with both left and right hand threads. I am going to move my bearings out toward the buffing wheels, so that the flexibility of the aluminum is not an issue. Plus, I like the lighter weight of the AL - but the $75 cost for the machined shaft is the major factor!
I am ordering my shaft to be 44" long, for two reasons. First, since the bearings and pulley will be next to the buffing wheels, there is no big hump in the middle of the machine that I have to keep the guitar away from, and thus can let the machine have a narrower stance. Second, I wanted to design it so that it could be stored in a standard four-foot shelf when not in use (I actually have some cabinets that I will keep it in, so that it won't get loaded with dust from my home shop, which is mostly in one room).
A couple of questions.
1) Since my pulley is going to be fairly close to one of the buffing sides, how far away should I safely keep it so that I don't have to worry about the buffing pad hitting it (when it is flopping around, getting up to speed)?
2) What recommendations would you give for how much thread I should put on each end?
Thanks in advance for your advice. Once I have this nailed down, I hope to get building.
If you have any last minute changes/suggestions for me, now is the time to speak up or forever hold your peace!
PostPosted: Sat Apr 13, 2013 7:01 am
Update for those thinking on using the go cart axle. I have mine finished and buffed 4 guitars with it so far with no complaints. It seems that only 1" of right hand thread is all that is necessary if you use locking nuts on the threads and locking collars on the inside flange. I know that 4 guitars is not enough to be conclusive, but so far I have not had any loosening of the locking nuts, and the locking collars (from Mcmaster Carr) have not moved and are made for using a wrench on them. Also, the go cart axle I received has .015" of run out, which is undetectable when running free and/or buffing. I am using 12" buffs from my old buffer and plan to go to 14". Also, running a 1/2 hp motor. Here are a couple pics of how I use it now...still need to mount it permanently.
Chuck
PostPosted: Sat Apr 13, 2013 8:27 am
I've got tons of machine shops in my area. I'll see if any are willing to do up a bunch of what folks are looking for when I get a chance.
If someone could provide me with a drawing & specs, I will do some research into some shafts.
Let me know what kind of steel, and critical dimensions etc.
PostPosted: Sat Apr 13, 2013 9:43 am
First name: Rienk
Last Name: Ayers
City: Santa Maria
Chuck, it looks good!
And I think four guitars is enough to claim some level of success.
I just received my two axles last week from the same place. Paid $75 each for 44" long 1.25" AL, with 4" of left and right hand thread, and a 6" keyway inside both.
I just ordered my low profile pillow blocks yesterday. I already have the pulleys and collars, so once I order the nuts and motor, I'll have everything to build mine. Hope to get started within the next month. I'm still working on building my home shop, so haven't even started my first guitar for the Challenge yet. I'll let you know how the buffer turns out when it's finished.
Users browsing this forum: Bing [Bot] and 17 guests
