It is currently Thu Aug 21, 2025 9:59 pm
Post new topic Reply to topic  [ 57 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Binding gaps
PostPosted: Tue Dec 17, 2013 3:17 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
Thanks david, I will ask my wife, they use this green stuff at their occupational therapy clinic. I might have some bands kicking around the house , to see how effective they are at pulling in the binding.I like the look of wood binding, but have so far found it a PITA. to install, Need more practice.
PostPosted: Wed Dec 18, 2013 5:48 am
I don't have photos of all the process, but you can see here how I use the tape only to put the binding in place before using the rope:
After the rope, which is cheap cotton, I put those wedges (pieces from 8mm spruce tone bars). They definitely add a lot of tension to the rope, but putting them like that they also push the binding vertically, which I find just as important. You can also put then at the surface of the sides, just in case you find that the wall of the binding is not vertical (this can happen if you use bindings taller than necessary, which shouldn't be done). Using the wedges to avoid gaps is like night and day, especially on archtops.
PostPosted: Wed Dec 18, 2013 9:20 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Good ideas with the spruce wedgies under the rope.keeping the binding down in the bottom of the channel.
PostPosted: Wed Dec 18, 2013 9:59 am
First name: David
Last Name: Ingalls
City: Ashland
State: OR
Zip/Postal Code: 97520
Call me "Fumblefingers" but that looks like a lot of chances to damage a softwood top.
PostPosted: Wed Dec 18, 2013 3:02 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
David look closely?the wedgies are under the tape ??. Perhaps WRC wedgies might work better vy soft ,or my favorite MDF.
PostPosted: Wed Dec 18, 2013 7:31 pm
As Duh Padma says there are lots of ways to skin the pig.... er... was it get the pig clean.... :)
Here is how I bind: http://www.lenaweelutherie.info/page6/page10/page10.html
Some things that are helpful are using bindings that are no thicker than say .065". Prebending the bindings so that they fit exactly and then very little tape, rubber band, rope, wishful thinking, etc. pressure is needed. You can use strapping tape too but if you fit the bindings well very little horse power is needed to make them fit well. And of course a proper binding routing jig also helps avoid the dreaded thinner binding on the top of the back's upper bout.
I also would dry fit my bindings and until they fit well the glue stays in the bottle.
As I built more my bindings got thinner and less deep mostly because I like the look of less bindings.
PostPosted: Thu Dec 19, 2013 12:25 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
hesh ,thanks read your excellent binding tutorial, an ordered the brown tape from stew-mac. I/ve been using the blue, and not getting the pressure I need. Still gonna use the upolsterers tape and theraband just to make sure!
