It is currently Tue Apr 28, 2026 9:16 pm
Post new topic Reply to topic  [ 75 posts ]  Go to page Previous  1, 2, 3
PostPosted: Fri Feb 26, 2016 9:29 am
I'm going to finish it and give him the choice. I'll show him the pictures and let him decide after he's played it. Might even let him keep it for a couple of weeks to decide, or even play it while I build another one if he is bothered by the repaired area. I put the purfling and binding on the top last night. I think it's going to be fine. I haven't planed it out yet, but I'll post a picture later.
PostPosted: Fri Feb 26, 2016 9:39 am
That sounds like a great solution, Waddy. I think it is a good idea to put it in his hands to play.
Andy
PostPosted: Fri Feb 26, 2016 10:18 am
Here's where it is at present. You can see the graft, but I'm hoping I can blend it in filling with dark sawdust and shellac.Image
And here is the top with the wider purfling scheme. Really matches the rosette just fine. Had to widen by hand since no bit would go that wide. Still need to plane it out. Image
PostPosted: Fri Feb 26, 2016 10:48 am
That's looking really promising Waddy.
Like the Purflings
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I think the patch will blend in with finishing. A wide purfling pattern is not uncommon in a classical. I think it looks great.
PostPosted: Fri Feb 26, 2016 11:12 am
Waddy the graft looks good but is that a gap between the binding and the white purfling line or an optical illusion?
PostPosted: Fri Feb 26, 2016 3:05 pm
The side purfling is BWB, so it's most likely where the purfling is sticking out beyond the binding since it's wider.
PostPosted: Fri Feb 26, 2016 8:13 pm
First name: David
Last Name: Riedmiller
State: WI
Looks great Waddy. I'm impressed. I like the purfling.
"It is easier to fool a man, than it is to convince him that he has been fooled"
Mark Twain
PostPosted: Sat Feb 27, 2016 8:02 am
Very nice save Waddy!
PostPosted: Sat Feb 27, 2016 8:51 am
If I didn't know it was a graft, I would think it was just normal variation in the wood. It looks fantastic and I doubt anyone would ever notice unless you told them. Great job!
Dan
PostPosted: Sat Feb 27, 2016 10:01 am
First name: mike
Last Name: mcgrail
State: ky
Great save/cover. Of course folks might take to calling you the undertaker....
PostPosted: Sat Feb 27, 2016 1:16 pm
Really nice job and thanks for posting. How are you going to change your routing approach after this? Climb cut all around at first?
Terry
PostPosted: Sat Feb 27, 2016 1:50 pm
an old saying among woodworkers is as follows: it's not that you made a 'mistake' buy how well you make it go away...
I give you an A+ on pulling that one off...
PostPosted: Sat Feb 27, 2016 2:39 pm
You guys are all too nice! I appreciate the kudos. One solution is that I ordered one of the Luthier Tools self aligning binding jigs, which uses a spiral down cut bit. The shearing action of the down cut bit should limit situations like this one. I hope! Using the bearings has been frustrating to me. Nothing is ever the right size. Constantly having to tape up a bearing or put tape on the sides to make it fit. The bearings also limit what you can do on top purfling. If you need to cut a shelf with more than a total of 4.5 mm you are out of luck. Back to hand cutting. Not so bad, as that's what I had to do on this one. However, sometimes I like to have a little wide purf scheme on the top. The Luthier Tool jig gives you a potential horizontal depth of cut of about 9 mm(3/8") if you happen to need that.
PostPosted: Sat Feb 27, 2016 3:17 pm
You done very good Waddy!!!
PostPosted: Sat Feb 27, 2016 7:46 pm
No one is going to notice that me thinks. I really liek that binding/purfling scheme too.
PostPosted: Sat Feb 27, 2016 8:54 pm
Waddy, great job! I bet after a while if you get a chance to see the guitar again, even you will have a hard time picking it out.
Let us know how you like the new binding jig. Binding is the most stressful thing on the guitar for me.
PostPosted: Sat Feb 27, 2016 10:09 pm
Me too! Now!!! gaah [headinwall]
PostPosted: Mon Feb 29, 2016 10:34 pm
Update. ImageImage
PostPosted: Mon Feb 29, 2016 10:51 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Very nice Waddy
PostPosted: Tue Mar 01, 2016 9:46 am
Nice!
How wide are your linings? I've heard tales of guys actually whacking off the sound board trying to install extra wide trim.
Ken Cierp
These users thanked the author kencierp for the post: Pmaj7 (Wed Mar 02, 2016 1:48 pm)
PostPosted: Tue Mar 01, 2016 10:07 am
That is outstanding!! Really good save Waddy.
PostPosted: Tue Mar 01, 2016 11:10 am
First name: Wendy
Last Name: W
State: Arizona
Beautiful save Waddy. I personally love classicals with wide purflings.
PostPosted: Tue Mar 01, 2016 5:59 pm
Thanks, everyone. I don't think it will be a knock out issue now. I don't object to wide purflings either. The problem is cutting the ledges for them. I was lucky to have a piece that was close enough to work. When I cut bindings off of sides, I always cut from the edge I like least.
PostPosted: Tue Mar 01, 2016 9:43 pm
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
Beautiful!
Users browsing this forum: Terence Kennedy and 330 guests
