It is currently Mon Jul 28, 2025 7:45 pm
 Post subject: Tail Block question
PostPosted: Wed Mar 19, 2008 5:41 pm
City: Jacksonville
What should the orientation of the tail block be.....end grain facing the top and back of the guitar or end grain standing up and not contacting the sides?
 Post subject: Re: Tail Block question
PostPosted: Wed Mar 19, 2008 5:48 pm
Tail block grain should run parallel to the grain of the sides.
Don Sharp
Got Brazilian?
http://www.sharpguitars.com
PostPosted: Wed Mar 19, 2008 5:50 pm
City: Jacksonville
got it.......thanks.......... [clap]
PostPosted: Wed Mar 19, 2008 7:48 pm
With the side grain and end block grain all lined up, it helps to inset a cross grain piece to avoid a split should the guitar get dropped on the strap pin.
http://www.chassonguitars.com
PostPosted: Wed Mar 19, 2008 8:06 pm
I laminate mine from two pieces of mahogany with the grain going in oposite directions for the same effect. Others simply use plywood; why not?
PostPosted: Wed Mar 19, 2008 8:11 pm
Also, consider using plywood. Won't crack.
PostPosted: Wed Mar 19, 2008 8:35 pm
City: Jacksonville
well......I used a mahogany one. Once I got the profile on it....it was all good to go....
PostPosted: Wed Mar 19, 2008 9:38 pm
First name: Tracy
Last Name: Leveque
State: CO
ToddStock wrote:
1/2" Baltic Birch ply.
That's what I use, light, stiff, and virtually indestructible!
PostPosted: Thu Mar 20, 2008 12:33 am
BB ply for me too. Make sure it's the good stuff, not the asian import.
-C
Freeborn Guitars
and home of BeauGuard©
PostPosted: Thu Mar 20, 2008 12:44 am
Where do you guys get your Baltic Birch ply? I don't recall Home Depot selling these...do I need head down to lumbar yard ?
Thanks, David
PostPosted: Thu Mar 20, 2008 2:20 am
David you'll have to go to your local wood vendor, most retailers who sell an assortment of hardwoods will usually sell Baltic Birch plywood.
I too use 1/2" BB for my tail blocks and am considering using two laminated 5/8" pieces for the head block.
PostPosted: Thu Mar 20, 2008 6:31 am
'home made' plywood (well, usually about 3 to 5 mm thick plys) made of mahogany and spruce, or just mahogany. It's not like I don't have the scrap, looks nice and clean, and the lamination (I use polyurethane glue) works just fine. Cheaper than baltic birch ply, since I don't pay myself for the time...
